Packaging and Contents
The F1 arrived in a very nice retail-quality cardboard box and packaging. The light was cushioned in a form-fitting piece of white foam. Below that were the clip, 2 spare O-rings, lanyard, USB cable, case/holster and manual. The packaging both looked very nice and protected the light perfectly. In addition, the box was inside a plastic bag to prevent the box from coming open accidentally as well as to keep the box in good condition.
1 x Zanflare F1 LED Flashlight
1 x USB Cable
1 x Clip
1 x Case / Holster
1 x Lanyard
1 x Manual
Fit and Finish
The F1 has solid and smooth black anodizing (Type III HA). The anodizing was applied well and seems thicker than many budget lights, even in the same price category. My copy did not have any notable defects in the finish. The anodizing was a smooth and non-glossy. I felt that this finish looks very nice and professional in quality.
The body of the light is a 18650-size EDC tube design that some people also may describe as an "S design". The width is wider than a dry erase marker and about the same length. Due to the design, there is minimal roll-resistance unless the clip is attached.
This light is slightly wider than some other 18650 tubes that I have used which will be preferred by people with larger hands. The light also feels solid and well-constructed.
The body has a unique diagonal pattern which adds grip and a clean look, and some scratch resistance. The pattern is very smooth while still adding grip. It feels very very nice in hand.
The threads were cut perfectly square and there is anodizing on the tail threads.
Comment: I originally wasn't sure whether or not I would like the diagonal pattern on the grip based on pictures. However, in person, the pattern is very nice and in fact I think that it works a lot better in hand than the traditional knurling on most lights. It's able to add grip while feeling smooth.
Built-in Charging and USB Port
The F1 features built-in charging. Mine appears to terminate charging <4.2V.
Comment: Built-in charging is very good (my preference) because terminating <4.2V is safer and will result in longer lifespans for batteries, especially for everyday consumers who frequently "top off" the battery via USB. I would have no qualms gifting this light to someone.
Lanyard, Case and Clip
The lanyard which was included in mine was on the short side and hard to put on even my relatively slim wrists. Fortunately, it was easy to replace the existing cord with some paracord which I already own.
The holster/case is also a very nice touch. It is a soft neoprene-type material and looks very nice.
The clip is nice material. However, I would have liked a deep carry clip.
Tail Stand
The F1 can tail-stand on a level surface and is stable. Also, there is a divot in the tail to allow the lanyard to sit without destabilizing the light when tail standing.
Tail Hammer
The F1 has the unique feature of having a built in glass breaker/safety hammer.
Comment: I did not test the hammer. However, I feel that if the hammer point protruded a little more, it would be more effective (although, it would also be more likely the scratch the user.)
User Interface and Modes
The light has a rear reverse-clicky (On/Off) and uses a side-switch to control modes.
There is mode memory. The light will activate on the last used brightness.
Strobe & SOS are hidden.
Operation:
- To turn the light ON, press tail switch.
- To advance modes, press side switch (Moon -> L -> M -> H)
- To turn the light OFF, press tail switch.
Flare (Hidden):
- To activate Flare mode, double-click side switch (when on).
- To exit Flare, press side switch.
- The light will automatically ramp-down from Flare to High after 30 seconds.
Strobe / SOS (Hidden):
- To turn STROBE ON, long-press side switch (when on).
- To change between STROBE and SOS, press side switch.
- To turn STROBE/SOS OFF, long-press side switch.
Comments: I like the mode order and mode memory. I will normally set the light to Moon or Low before turning it off so it will always start low. Because the mode and power switches are different, it's very easy for me to always change the mode back to Moon/Low before turning it off. The side switch is very intuitive and I also like that the strobe modes are well hidden as I never use them.
Output, Runtime and Power
Measurements were done using a freshly charged EVVA protected Panasonic NCR18650B.
I estimate that the Zanflare official specs are all correct. For Flare, I measured 1303 lumen initially and 1254 lumens at 30 seconds, right before it steps-down.
The Flare mode gives a nice boost for maximum output and then ramps down to High at 30 seconds. The ramp-down is smooth. On High, the light gets comfortably warm and is usable for extended periods.
"Moon" mode is right around 1 lumen and perfect for people who want to preserve night vision in a dark area.
PWM
I did not detect PWM via video method. If it has PWM, it is very high frequency.
Regulation
This light has a timed ramp-down from Flare back to High at 30 seconds. The ramp-down is smooth. When I used the light outdoors, walking around, the ramp-down was not that noticeable (although it would be in a static environment such as a closed room).
Comments:
* The user can manually step back up to Flare if desired.
* The light does not get that hot on High.
* This test was done with a constant cooling fan. Ambient temperature in my house was 80F (27C).
* Moon and Low have very long runtimes.
Beam Profile
Balanced General Purpose. The F1 uses a domed Cree XP-L V6 in a polished reflector. The beam is very balanced for general purpose use with a relatively large hotspot. The hotspot is large and transitions smoothly and gradually throughout the beam. The beam has smooth defined edges. This light works very well for people seeking a more balanced beam. This light works great for general purpose use both indoors and outdoors.
Beamshots, Color Temperature and Tint
The F1 "Neutral White" is a very nice warm neutral white at 4750K. When white-balanced in Adobe Lightroom against "Daylight 5500K", the beamshots appear slightly warm to neutral. The light appears slightly warm white in practice. This is a very good choice of color temperature and I'm really happy to see a manufacturer using this color temperature for a light.
Lightroom detected a green-shift of approximately 14 points as compared to Daylight (using exposure 1/100 - F/2.8 - ISO 100). This is within range of other lights I've seen at this price-point. It did not stand out to me in real life or in pictures.
Low Voltage Protection (LVP)
This light has LVP. The light will shut-off around 2.6V.
Battery Support and Fitment
The F1 is powered by 1x18650 lithium-ion (INR, IMR, ICR, etc.)
Protected Batteries Fit. The EVVA Protected Panasonic NCR18650B fits fine length-wise at 69.5mm and width-wise at 18.67mm.
Button vs Flat-Top: The Panasonic battery is button-top. Flat-top batteries might work if the flat-top is raised. The positive connection on this light is flat so if the positive end of the battery is recessed, it may not contact without a solder blob.
The positive contact is flat.
The negative contact is a spring.
Lock-Out
You can physically lock-out the light by loosening the tail (or head) one-half turn to break the circuit.
If there is a possibility of accidental activation, you should lock-out the light.
Manual
Size Reference
Flashlight pictured next to a AA, 18650 and C8 for size reference.
Other Reviews
Summary and Conclusion
This is a very good, well-built 1x18650 EDC tube light which performs at spec at ~1250 lumens on Flare and ~600 lumens on High. The light is easily capable of sustained run-times on High. The built-in charging works well and safely charges batteries to under 4.2V, which is good for improved battery life and safety for average consumers. For people who mainly use Low or Moon, this light will provide great run times. The modes are well-spaced and Moon is perfect at 1 lumen. I also like that Moon is part of the normal mode rotation (not hidden). Hiding the Flare mode is good for most consumers since otherwise the ramp-down at 30 seconds would be confusing and also helps protect the light from being abused or run too hot.
This size light is a good 18650-sized EDC. Although the F1 is slightly wider than some other 18650 tubes, it will fit comfortably in dress pants, cargo shorts, jacket, etc. The finish looks excellent, is clean and my copy had no defects.
The beam profile is very balanced and is well-suited for general usage. My copy was a very pleasant 4750K color temperature (warm neutral). I like the trend of manufacturers offering "neutral white" lights in this color temperature range.
