Reviews Nextool's 12-in-1 flashlight with built-in speakers.
I told myself not to buy flashlights anymore - too many. But with Nextool’s new product launch, passion wins all.
This is my detailed clip about Nextool’s latest flashlight
With the price of 38$, I find this to be a really great choice. Some highlights I think you might be interested in are:
Nextool 12 In 1
Coupons: XTNEXTOOL12
1- Design
  • The lamp is finished very high-end, beautiful design. The metal position on the light is made from 6061 aviation aluminum. The plastic position is quite nice with 3 main materials: ABS, PA66 + 30% GF
  • The lamp weighs only 246g with a body diameter of 36mm for a good grip, no hand fatigue when used for a long time.
  • With 12 features in 1, our lamp does not lack any feature. Maybe it will be a bit redundant I will tell in part 2.
2- Features
  • The most special feature on Nextool 12in1 is the alert mode. At this time, the light will activate all leds on the light including 4 main leds, white leds, color leds on the edge and speakers. The sound of the speaker is also quite special, although not loud, but can be heard at a very long range. Please see more in the clip.
  • The main LED of the lamp is integrated with 4 leds: White, red, green, blue.
    Each color on the lamp will have a very specific task as green light will serve the purpose of animal observation because some animals have little response to green light.
Zoom for close projection, you will see 4 leds at the top of the light
  • The lamp head can be zoomed for very flexible lighting. We will have a very large illumination area when we need to observe at a close distance or reduce the light beam to observe at a longer distance.
    Zoom to project far will not see 4 leds inside
  • The white light on the LED on the side of the lamp is very well finished for a very even beam.
  • The LED next to it has 5 usage modes that will change with each press. The first is white light, color light, color light flashing to the music, red light, red light flashing as a beacon.
  • The In/Out charging port is hidden inside the tailgate, which is very aesthetically pleasing and has a waterproof effect, which is also a bright spot in the design.
    The charging port is covered, the other small slot is the music playback position of the speaker
USB-C charging port (5V-1A), takes about 3.5 hours to fully charge the 2600mAh battery
USB-A output with backup charging with 5V - 1A charging current.
  • The side of the light has a plastic bar with a ¼ inch tripod hole with built-in magnet. Nextool has added a spacer on this plastic bar to avoid scratching the metal positions when attaching the light. This is a small but quite subtle improvement over the previous version.
Plastic rod with special design allows us to rotate the led at the edge 360 degrees for more flexible lighting.
The plastic bar on the side also has a place to fasten the strap
  • Using the light is simple with an intuitively designed tail button.
  1. Press in the middle 1.5s to turn on the light.
  1. Double click to switch back and forth between the main led and the side led
  1. + and - signs to increase or decrease the brightness
  1. Hold the middle button for 3.5s to activate the light and sound alert mode
  1. Hold the button shaped like a musical note for 2s to activate the bluetooth speaker
  1. Click the bottom button to next song or double click to go back to the previous song
  • IPX4 waterproof standard helps me to use the light with confidence in many weather conditions
3- Should buy or not?
  • Good price, high-end finish, many features, high brightness up to 900 lumens can zoom with many colors suitable for use in many situations… I rate this as a great product.
  • Beautifully packaged, easy to use, if you have not yet chosen a gift for your loved one, Nextool 12in1 is also a good suggestion.
  • As for the speaker on the lamp, I only mentioned it until now because I think - you and I will not use a 2W speaker to listen to music. We always use the phone for your convenience.
Thank you for reading the article. Hopefully, through this sharing, you will be able to choose the right product for your needs. Subscribe to my Youtube channel and Fanpage to see more products.
4- Some more pictures
Brightness and usage time of each led: green, red, white…
White light on main led with brightness 900 lumens
The main LED with 4 colors can zoom like this when you need to project far
Red light
Green light
White led on the side, color led you see in the clip
