Hello, today our RK6006-C is released, it is AC to DC power supply version based on RK6006. Hope you like it and you can check the product information and make order in the link below:
As what we do all the time, we will set the lowest price when new product is released, so here is the price:
RK6006-C: 74.99USD (normal price:$84.99USD )
C400(case and input PSU): $46.99USD (normal price:$51.99USD )
Discount Time: 2023.6.29-2023.7.5 PT(7 Days).Limited quantity
This is the RK6006-C accessory list:
It contains the device, output cable, communication cable, backup fuse, for the input AC power cord, it needs to be prepared by yourself, it also does not have the external temperature sensor cable Here are some important features about RK6006-C:
·Support 100-120V/200-240V AC input(AC selector)
·Support 60V 6A max output
·Low ripple: 100mV VPP output ripple typical
·Custom display color and display style
·1.54 inch HD display
·PC software/APP control/support firmware update/multiple protections If you already order RK6006 or RK6006-BT before, you can order the “C400” option, it includes the case and input AC to DC PSU.
If you have any questions about RK6006-C, you can contact us in the way below:
Contact us on Aliexpress directly
Contact my email:1749808860@qq.com
WhatsApp: +8615868147353
WeChat: 15868147353
Technical parameter
Model: RK6006-C
Input voltage range: 100-120V/200-240V AC
Output voltage range: 0-60.00Vstrong text
Output current range: 0-6.000A
Output power range: 0-360W
Output voltage setting/reading resolution: 0.01V
Output current setting/reading resolution: 0.001A
Output voltage setting/reading accuracy: ±(0.3%+3 digits)
Output current setting/reading accuracy:±(0.5%+5 digits)
Output ripple typical:100mV VPP
Working temperature range: -10℃~40℃
Constant voltage mode response time: 2ms(0.1A-5A Load)
Constant voltage mode load regulation: ±(0.1%+2 digits)
Constant current mode load regulation: ±(0.1%+3 digits)
Capacity measurement range: 0-9999.99Ah
Energy measurement range: 0-9999.99Wh
Capacity and energy statistical error: ±2%
Over temperature protection: System temperature>90℃
Screen brightness setting: 0-5(6 level in total)
Screen: 1.54 inch 240240 color LCD display
Weight(with package):About 1.3 kg
Product dimension: 200115*57mm
Support USB/Bluetooth communication: yes
hello, the promotion for RK6006-C and C400 lasts 7 days, and after that, the price will back to normal, C400 price will be 51.99 USD at least, RK6006-C will be 84.99USD at least , if you already have the RK6006, it is a good time to take the C400, please notice that
hello, it is already the second day of the promotion, and for RK6006-C, it is sold at 74.99USD, from July 6th it will back to 84.99USD, for C400(Case and input PSU), it is sold at 46.99USD, after the sale, it will back to 51.99USD, please notice that
hello, there are still 3 days left for the RK6006-C sale, if you need it, you can make the order now, RK6006-C is 74.99USD now, and from July 6th, it will back to 84.99USD, and if you already have RK6006 before, you can order the C400, it is 46.99USD now, after July 6th, it will back to 51.99USD. please notice that https://www.aliexpress.us/item/3256805243272337.html
hello, there are 2 days left for the RK6006-C sale, it is sold at discount price 74.99USD now, please notice that, from 2023.7.6(PT) it will back to 84.99USD, if you already have the RK6006, please check the C400 option, it has 5 USD off now https://www.aliexpress.us/item/3256805243272337.html
there are still some stock for the sale, so that we last 4 days for the promotion, end at July 10th, the price of RK6006-C is 79.99USD(later back to 84.99USD), C400 is 49.99USD(later back to 84.99USD)
RK6006-C feedback
Everything arrived as promised on time. Packed well in a cardboard box, Works fine. Made neatly. Small, handy, easy to transport. If you have not used Ruideng converters before, you will have to get used to it.
