This is a review of a great torch which I got from GearBest.
See product details here…]Roche M170 Cree XM-L2 3-Mode 2400LM Highlight 3-LED 4000-5500K Flashlight Torch (3C 4 x 18650)–66.77 and Free Shipping| GearBest.com
Use coupon code: M170CM
Features:
- 3 X XML-2 LED (2400 lumens on high)
- Stainless steel bezel
- Aluminum reflector (smooth)
- AR glass lens
- 3 mode (H,M,L) Also can enter a variable dimming mode
Some Pics:
Batteries:
Uses 4 X 18650 cells in parallel…
Comes with the adapter shown in my picture below in case you want to use the shorter non-protected cells. It also fits protected cells button top or flat…
Tripod/handle mount:
Has a tripod mounting plate.
It also comes with a handle that can mount there if you desire…
Spot and throw:
I was impressed with how tight the spot is with this multi-LED light!
Here’s a picture at 30’…
Notes:
Very high quality craftsmanship in my opinion. And looks really cool too. Like a smaller version of the FF4!
I like the modes. H, M, L (no strobe) If you double click, you can also enter a variable dimming mode. I leave it in the H, M, L operation because I like that best…
5500K temp is perfect. Has memory too.
Switch operation is flawless. Hold for a second to turn on. When on, each press of the switch will switch modes.
Hold for about 2 seconds to turn off…
This is a great value, quality 2400 lumen torch!
