Running multiple LED's - what driver works?
Just curious on this one.
Say if I wanted to run 3x XM-L2, could I use something like a single Qlite 3.0A driver to do this and simply wire the LED’s up in parallel? This would give (battery dependant) 3’ish amps to each emitter right?
Would this likely cause a driver issue, such as heat, durability or something?
Should I only use drivers specifically stated for supporting multiple LEDs?
If you run the emitters in parallel using a single Qlite, the current would be split between them, resulting in about 1A/emitter.
You want to run each emitter at 3A?
Essentially yes.
So series would = 3amp per emitter in this setup?
If my brain is correct, to run 3 in series at 3 amps you would need to triple the driver output voltage with some kind of boost driver. The boost circuit would pull more amps out of your battery, but output at ~9volt and 3amps.
To run them in parallel at 3 amps each is doable with many drivers, but your battery will need to provide 9amps. Driver would output at ~3v and 9amps, but the nine would be split between the 3 emitters for 3A each.
If you just use a standard qlite, it wouldn’t even turn on with the LED’s wired in series. If they were wired in parallel, each emitter would only see 1A, because a standard qlite outputs 3A total.
That’s why for triple builds most people use the FET drivers or stack a bunch of 7135’s
edit: all of the above is based on using 1 battery. if using multiple cells, you can pretty much disregard all of it
i’ve build few lights with multiple xml. i never did all in parallel, not the best idea, imo. a lot easier to work with higher voltage, than high current.
all depends on power you using, if just 1 cell to feed all the leds, you could wire parallel, but than you’d need to supply with 9A. you can use boost driver, thou i have not seen such boost driver sold, that will work with just 1 cell, most boost drivers need more voltage to work. even if you get one, you’d still need to supply 9A or even more.
imo the best way to do is to use 3+ cells in series, and use either buck driver, or in case of 3 cells, linear driver, just not amc based linear driver. taskled lflex would work in this case
i had great luck with both, taskled and der witchel driver buck\dd that is sold on cpf.
if you do not need any modes, you could use 3 separate amc 1 mode driver, 1 for each led, input of all drivers wired in parallel. but than another issue, you’d need power button rated at 10A.
Thanks for the info. I was probably misleading with 1 cell and Qlites. Was just trying to understand multi setups better, but seem to have confused things.
I’m building a triple Mag and I want to run 3 emitters at around 3amp each. I have two setups I’m considering either a 2D running 2x26650’s or a 6D running either normal D cells or Eneloops. What sort of driver setup should I be looking at to achieve this?
You can use one cell with one driver and two slaves or you can use three cells in series with a zener moded Q lite. WRT the cell combination you mentioned, I’m a little stumped. sorry.
There’s a 5amp buck driver floating around that you might be able to resistor-mod and get another amp or 2. That would work with the 2x26650’s to get about 2amps to each emitter.
I’m also stumped on the 6D mag though
