Runtime \ Beamshots \ Review Sofirn TF84 (18650, great UI, Type-C, LH351D 5000K) budget tactical flashlight
Sofirn produced a number of interesting models in almost all segments of the flashlight market. And if budget Sofirn SP40 mainly corresponds to its price, then damn convenient and functional Sofirn C8G and (especially) LT1 surpass their price tag. I offer you , gys, to see if Sofirn TF84 is the same good. Will it be budget bestseller for those who want to choose a good affordable tactical flashlight or not.
You can buy Sofirn TF84 at:
AMAZON
As a result, the flashlight + battery comes out at $ 42, and with a remote button the price tag will be $ 47. That, compared to other tactical flashlights, is a mere penny.
SPECIFICATIONS:
Emitter: 1x powerful LED (should be LH351D, which is obviously not powerfull -) ) with a lifespan of 50,000 hours
Operating voltage: 2.8V – 6.6V
Driver: Constant current buck driver
Battery options: 1x 18650 rechargeable or 2x CR123A lithium-ion battery
Dimension: 143mm (length) × 35mm (head diameter)
Weight: 120 grams (without battery)
Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized to military grade specification type III, anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
Toughened mineral glass lens
Water resistance i.a.w. IPX-8 (up to 2 meter under water, not for diving)
Mode Memory: memorizes the last brightness level used in the general modes
Reverse polarity protection from improper battery installation
Low voltage warning: When the battery voltage is too low, the LED indicator in the side switch will start to flash rapidly. Please recharge the 18650 battery or insert new CR123A batteries.
Low voltage protection: The flashlight steps down automatically when the voltage is lower than 3.0V. It also turns off automatically if the voltage gets too low. Please recharge the 18650 battery or insert new CR123A batteries
Advanced Temperature Regulation (ATR) technology: As the temperature rises, TF84 is programmed to automatically step down and step up the brightness.
PACKAGE AND APPEARANCE
The package is at the lowest level, as usual for other Sofirn models. For the sake of the lowest price, the manufacturer cuts off all the excesses. That is as good for personal use as bad for gift potential.
I got almost the fullest kit, including a flashlight, 3000mAh battery, Type-C charging cable, remote button, O-ring and manual. There are several configuration options, here you can choose what you are interested in. Currently you can also add red diffusor
Similar to the package, flashlight itself has really budget design. Do not expect any delights, colored bezels and other attributes of stylish thoroughbred models here. Sofirn FT84 only looks better than Convoy tactical flashlight if it were released.
In short, everything is as before - Sofirn TF84 is a simple workhorse with simple design. As any other Sofirn model.
143mm is a completely common length for a tactical flashlight, there is nothing unusual here. There are models that are slightly longer, there are slightly shorter ones, but, in general, this is a completely medium-sized tactical flashlight.
And if Klarus models with the photo above are favorably distinguished by their stylish visibility, then Sofirn makes them easy to control on the fly. In addition to the standard set of tail-button + swing (it is worth recalling some “tacticool” models from major brands still doesnt have it), there is also a side button on the head of flashlight.
I really, really like this. You can operate flashlight with direct of reverse grip. As EDC or Tactical - as long as UI is logical. And, i`ll say in advance, it is.
The tail cap can be unscrewed and replaced with a remote button. I didn’t like that with a very short wire and a small button makes some click when pressed. And having got used to the magnetic fastening of remote buttons in expensive tactical flashlights, that`s hard to welcome this traditional one ) but, to be objective, what ELSE would you expect for 45$?
The side button is pretty cheap. Non-anodized round with indicator in the middle. However, it is easy to find it blindly - and losts of more expensive models can pass this test. At the same time, you can see that there are quite lot lot cooling find. Edges are not sharp.
It should be noted that the button sticks out quite strongly. If you put the flashlight down with the button, it can be occasioanlly pressed. And unscrewing the tail button will not help, there is still contact on the non-anodized thread. The safest way 4 clicks electronic lock. Both the side and tail buttons have a slight backlash.Just like 1mm of move that doesnt do anything. Well, chance are low that you notice it if dont look for this backlash specially -) so that`s not a problem for me.
Dual springs of course. I didnt tested how they withstan recoil. Just shoow flashlight strongly and didnt see and contact break.
The thread is not anodized. There is an additional contact sleeve which is great, as it make UI more flexible and lets you use any sort of battery. The same Nitecore and Olight prefer to use their own expensive batteries for the same funtionality. Klarus also goes the same unwelcomed path.
The knurling is the simplest, but the flashlight fits perfectly in the hand.
The head is compact and compact. On the back side of the button, there is a deep and securely closed Type-C plug with a tight plug.
The bezel is simple, non-anodized, with medium-sized teeth. Looks like aluminium one, so this is sort of “ah, i`m so aggressive, were is my teddy bear?” bezel.
Reflector is SMO, with a LED unexpected for the tactical flashlight. One would expect LH351D 5000K in some gourmet model with beautiful quality light, but not in a tactical flashlight.
I didnt find any AR coating on glass.
That’s all. A very successful combination of controls, fast charging and a high-quality LED wrapped in an extremely simple flashlight body. The gift potential is low. It needs time to reveal reliability , i cannot check it during short-time review of Sofirn FT84. If this tactical flashligh has the same succes as Sofirn C8G does, there will be lot of user feedback quite soon.
UI
Extremely convenient, in my opinion.
Much much better than anything I’ve seen in the most expensive tactical flashlights from major brands.
I probably won’t get used to the 2-click instant strobe of the side button. All the time I expect that 2x clicks
here is copypaste from manual.
There are two switches on tail, one tactical main switch for ON/OFF and the other is mode switch for Strobe. Also, side switch on the neck changes brightness.
Two groups: Outdoor group(default) and Tactical Group are available to choose.
Toggle between the two groups
While flashlight is off, press and hold the side switch and tail mode switch for 3 seconds, it blinks once while from Outdoor Group to Tactical Group, blinks 3 times while from Tactical Group to Outdoor Group.
Group 1: Outdoor Group
Dual tail switches
Half press the tactical main tail switch for momentary-on, release for off. Press all way down and release for constant brightness, another click for off.
While tactical main tail switch is off, press and hold the Mode tail switch for Strobe, release within 2 seconds for Strobe off, release after 2 seconds for continuous Strobe.
While tactical main tail switch is on, click the Mode tail switch to select brightness in the order of Low-Medium-High-Turbo. If you press and hold the Mode tail switch for more than 2 seconds, it gives continuous Strobe, another click goes to Turbo.
Side switch
While off, click side switch to choose brightness in the order of Low-Medium-High-Turbo, press and hold for 1 second to turn off (if the light is turned on via tactical main tail switch, you have to click tactical main tail switch to turn off. )
While off, press and hold side switch to moonlight(1LM), another click to standard brightness, press and hold for 1 second to turn off.
Double click side switch to Strobe, another click to cycle through Strobe-SOS-Beacon, double click to the previous status.
4 clicks to Lock-out side switch, another 4 licks to cancel lock-out, the main led blink twice to inform success. While on lock-out status, side switch won’t work except 4 clicks. If side switch is clicked accidentally, switch led indicator flashing in Green/Red to remind the Lock-out status. During lock-out status, the tail switches work.
Group 2: Tactical Group
Dual tail switches
While tactical main tail switch is on, click the Mode tail switch to select brightness in the order of Turbo-Medium. If you press and hold the Mode tail switch for more than 2 seconds, it gives continuous Strobe, another click goes to Turbo.
Side switch
While off, click side switch to choose brightness in the order of Turbo-Medium, press and hold for 1 second to turn off (if the light is turned on via tactical main tail switch, you have to click tactical main tail switch to turn off. )
HOW SOFIRN FT84 ILLUMINATES
I like stabilization and mild influence of thermal control. There is no crazy zigzag here. Depending on the cooling, turbo will either drop to half or gradually slides from 80% after 3 minutes. Overall - good.
1200 lumens is an openly mediocre maximum brightness by modern standards, even if you take it on faith that this is what you get at the maximum (looks like Sofirn TF84 is not even this bright).
But if you don’t look at the numbers, then you get a light that will undoubtly cover all your needs within a hundred meters. That is, at such a distance of illumination, Sofirn TF84 can be safely used with the same smoothbore guns. Maximal useful throw is arount 200-250m in turbo, which is not that bad for such LED+brightness combination.
And here we have major advantage of Sofirn TF84 - its color temperature.
With rare exceptions, for example, amazing Acebeam L35 (review), manufacturers of tactical flashlights use cold light to gain each possible extra lumen for promo-pics. Such advantage of some higher brightness is visible more in promotional materials rather then alive. And if you use such a cold-light flashlight in smoke or, what is more relevant (tactical flashlights are still actively used by hunters) in the fog, all this small increase in lumens turns into a terrible reflected light. Where the warm light breaks through the fog, the cold one highlights all the moisture scattered in the air.
My opinion is that you can easily distinguish brands that care about user from those who are more ” no matter, they`ll still buy it” simply by looking at color temperature of their model. Cold white only? No, thanx. Ah, once you`re BLF member, you already know it, dont you?
Yes, Sofirn TF84’s 5000K is not the most penetrating color temperature like 4000k is. But it is much more comfortable than the exceptionally overwhelming majority of other tactical flashlights, where your choice is limited to the fork of “cold” and “cold and green”. BTW, i personally would pick 5000k for any needs besides camping and long-range illumination and where 4000k is best option.
50m
75m
250m
there are much more alive footage in my Sofirn TF84 utube review
OVERALL IMPRESSION
Once again: only time will show the reliability, convenience and practicality of the actual use of the tactical flashlight in specific hunting / guarding / combat situations. My review of Sofirn FT84 is purely peaceful, as we call it “sofa-review”. Objectively, I can only evaluate light , stabilization and UI. and i evaluate `em high.
Sofirn FT84 seemed to me quite confident Sofirn debut in the segment of tactical flashlights. Yes, it has a damn budget design and package. But in many respects it is due to this that the flashlight received a frankly low price for this kind of flashlights. $ 42 in the minimum configuration “flashlight + battery” is almost half the minimum price for brand tactical model. And i`m not talking about some really tactical stuff like Surefires.
And, in fact, Sofirn FT84 is budget only outside. And it is completely wrong to judge by cover.
But in terms of its functional characteristics, I sincerely like the flashlight. It normally keeps max brightness when cooling, and does not drop it after a couple of dozens of seconds or does not go into the “saw”. And this brightness is modest by modern standarts, it will be enough for you for almost any situation except for long-range work at distances.
5000k here is a sensible compromise between the cold light familiar by 9 of 10 tactical models and quite yellow 4000k . Again, personally, over the past few years, I have found 5000K to be the optimal color temperature for everyday use. Although, of course, this is a matter of personal choice.
Although its use in a tactical flashlight puzzles me, whatever one may say, you get one of the best quality LEDs in terms of light quality - the LH351D. And I am sure that for some people this combination of control and light will make the Sofirn FT84 a personal EDC model.
The aforementioned control of this flashlight is completely non-budgetary, head and shoulders above the radically more expensive models. This may be the weak point, actually. Ordinary shitfire user who is accustomed to UI like “three modes and on-off”, this control (no matter how convenient and logical it may look for a more or less experienced user) can lead to a nervous bursting of blood vessels in the eyes.
There are also moments that I did not like, in descending order:
a) wire of remote button seems for me (though one hunter told me 20cm is ok) too short, and button is clicky
b) the side button sticks out too much. can get pressed if placed on a flat surface
c) the flashlight turns on if you put it on charge with the tail button pressed.
d) only electronic lock is 100% reliable, no goode olde tail cap off way.
I also think that Sofirn should have made this model 3-4 dollars more expensive, but transfer it to 21700 power.
In the meantime, for its promotional price, the model seems to me undoubtedly an interesting solution for light and control. Provided that you are not jarred by the simple design and turbo at the level of 5 years ago.
Once again, I emphasize that my Sofirn TF84 review is a purely sofa character and only time will tell how comfortable the flashlight is when gun mounted.
