If you can make a host with a short body that takes an 18350 I'm in. Since I started vaping I've collected some good IMR 18350 cells that could drive a nice triple LED hot rod shorty. 16340's just don't cut it any longer.
It will provide some start current limiting with fresh battery, but will quickly (within seconds) fall out of the regulation and go into direct drive.
So I don’t quite understand why use driver at all…
The S2+ reflector is about 7mm shorter than the regular S2, so in order to fit a triple we need a much thinner spacer than the one RMM sells. Too bad the S2+ pill despite being taller doesn’t have a thicker led shelf…
Would be nice if someone could make a tall, threaded solid copper pill exclusively for triple builds.
Can the CR123A version be ordered with 2*7135? For a small single mode light, I would prefer to have a little less light with longer runtime. If it can’t be ordered with 2*7135, I can remove one 7135 myself.
Other than lower output, are there any downsides to running the light with only 2*7135?
