7x cree XHP 70 leds
7x random ebay reflectors
7x random ebay voltage/current adjustable drivers
ebay heatsink
80 mm computer fan
Running off a 4s Lipo.
Heatsink cut to shape
Led Locations marked.
Leds Mounted, also used heatsink compound.
Enclosed the heatsink to force the air to flow parallel and exit to outside of torch.
Ready to adjust then install the drivers.
Total Amp/Watt draw
Front protection added.
Un Assembled view.
My car on low beam, there is more light than what is shown in these next pics , however the camera was set to manual so its still a good indication of the different output.
That’s pretty impressive for only pushing to what’s on the spec sheet…. You can find some tests by members on here where they push them to the limits. You can go pretty far beyond what the specs list without facing problems other than more heat to dissipate.
Nice. I agree with The Driver. I would shave the LEDs for more throw.
You are driving each LED at around 25W. They can handle double or triple that pretty reliably. And I guess your active cooling could also handle the extra load? And it looks like you have a lot of room for batteries in there!
