Hello all, new member here to hopefully pick some brains.
TL;DR
Can anyone suggest a Search and Rescue torch with the following (possibly unrealistic) requirements:
- Push Pull Zoomie
- 3000 LM Flood beam
- 1500 LM, 250 kCd Spot beam
- 400/500LM constant output (no stepdown)
- USB onboard charging
- Handheld size
- Rain Proof
- 3hrs burn time at 400LM (would a single cell 21700 manage this?)
- ~ £100
Long version with explanations:
I’m a member of a UK Lowland Rescue (UK search and rescue is split between Mountain Rescue and anything that’s not a mountain!) team and I’m looking for a new “ideal” torch. I’ve been doing the rounds of the forums and the different “enthusiast” manufacturers over the last couple of days and haven’t found something that would exactly meet the specifications - maybe I’m asking too much from the currently available tech?
The current torches that I (and almost all members of the team use) are up to the job - I suppose I’m more interested on what’s available for us to use and if there’s anything that would constitute a significant advantage over our current equipment.
The current “Go-to” torch for most of our members is the LedLenser P7R, which costs around £100.
There are some important aspects of the P7R that make it popular:
It’s a Zoomie.
This seems to be the most controversial point when talking to enthusiasts! It is important as there is frequent change from close range searching (large even spill) and long range spotting (good throw). I find the zoom state being constantly changed during use, so the fact that it is a PUSH/PULL zoomie and not a TWIST zoomie actually becomes a fairly major factor to the torches ease-of-use.
The usual argument against the use of a zoomie is either to have a good hybrid torch - this isn’t usually great as they usually require a higher power setting to get a usable spill area for searching (burn time is important on a long search) or to carry a dedicated thrower and a dedicated flooder. This is very sub-optimal as it takes even longer to switch torches than it does to twist to zoom!
Requirement: Push/Pull Zoom
It has reasonable power.
The P7R outputs around 1000 lumen OTF. In SAR the higher settings are usually reserved for spot modes when searching distance - a good example of this would be scanning the hedge line on the other side of a field. The kcd on the P7R isn’t incredible, I’m not sure what it is, but the throw is only rated to 300m and it struggles for this distance. The width of the zoomed hotspot is good - wider beam is useful for searching, but realistically, it needs a higher output to maintain that beam width with a higher kcd. A great SAR torch would ideally have around 250 kCd when zoomed as this would give a reasonable “searching” distance of up to 500m. I’m guessing around 1500 lumen output at this kCd would still give a good beam width? A wide bright flood is great for lighting up a whole area of grassland at once though, it’s super useful to jump to the high setting and quickly check off a large open area with a good flood. Both of these mean that a higher output wouldn’t need to be maintained for more than ~30 seconds, so this brightness level on turbo is fine. Constant output of around 400/500 lumens would be great.
Requirement: Flood beam ~ 3000 Lumens
Spot beam ~ 1500 Lumens, 250 kCd
Constant output ~ 400/500 lumens without stepdown
It’s rechargeable inside the torch.
Search and Rescue operatives are good at searching, less good with technology (usually). Having it rechargeable inside the torch is probably a hard requirement rather than having to work out dedicated charging solutions. It is also genuinely very useful to be able to charge off of a USB cable in the car or incident control vehicle rather than needing to charge at home.
Requirement: USB charging in the torch.
It’s a smaller/medium sized torch.
These torches are carried for hours at a time and need to fit in load vests and other storage. Coke can size is going to be too wide and anything over 20cm/8in is likely to long.
Requirement: It needs to be a smallish handheld.
It’s pretty weather proof.
We have dedicated diving torches for our water operations, so there’s no need for a submersible rating (though it would be nice for peace of mind) however it does need to be resistant to anything up to submersion. The torches are going to be used whatever the weather!
Requirement: Fully torrential rain proof.
It has a reasonable burn time.
SAR torches are usually run on medium brightness levels with the odd burst of high power. Given that searchers need to be able to go for 8 hours without returning to base, the torch needs to keep up with that. We are able to change batteries “in the field” but we don’t want to be stopping the whole team to do this every hour. I’d expect the torch to manage up to 3 hours on a mid-burn level.
Requirement: 3 Hour burn time for around 400-500 lumen output.
Price.
The fact that the go-to is a relatively expensive P7R shows that SAR operatives are happy to spend a bit extra for a good torch! The kit we buy is self-provided, however. Most of our kit isn’t team issue, unfortunately. This means that it can’t cost the earth as at the end of the day, as a volunteer has still got to be able to afford it.
Requirement: ~ £100 cost.
What do we think, am I totally dreaming for this kind of a torch with todays tech? The closest I’ve been able to find is something like a Convoy Z1 (I’ve put an order in to see what this is like) though I can see that it’s not quite the spec for a couple of points - Not USB chargeable, twist rather than pull zoomie and the 2300LM output is good, with reasonable throw, although slightly longer throw/higher output would be nice as well.
Can anyone suggest anything to fit my (highly demanding) spec list, or am I going to need to wait a bit for technology to catch up?
