YuvalS
(YuvalS)
1
Hi all
I am building a caving light using a handmade host.
I am searching for a momentary switch that need to be:
- Reliable
- ip67 waterproof or better (possibly by using a boot)
- mudproof (possibly by using a boot)
- About 16mm diameter
For my previous light I used APEM ISR3SAD300 which is:
- Cost more than a compete Convoy S2+
- Get stuck in muddy caves
The mud problem can be solved by using a sealing boot but is cost 10$ for a simple silicone boot :(
Any recommendation for a cheaper (but still reliable) switch?
Mike_C
(Mike C)
2
I’ve used this one: https://www.newark.com/c-k-components/k12c12-5n/switch-1mm-travel-2-5n-ip67-seal/dp/58T4766
It’s 12x12mm though. It worked well but note that I didn’t use it for very long before I decided I wanted a lighted switch instead. I haven’t used any other IP67 rated switch.
YuvalS
(YuvalS)
3
It is strange, the switch is sealed but it is connected to the body only by clips, no thread and no O-ring
Mike_C
(Mike C)
4
I didn’t care about that. I just wanted the actual switch to be rated, I took care of the sealing to the flashlight body myself with epoxy.
