See the battery range before Anduril finishes blinking - my first Anduril mod
My first Anduril mod adds battery-voltage colors to the usual 3C battery check. I call it Voltage Colored Number Blinks.
I keep the post-off voltage display disabled on some of my lights, but I still want a quick battery check when I need one. With this feature, the first blink gives a rough voltage range with its color. Keep counting for the full reading (for example, 3.98 V still blinks “3-9-8,” in blue).
It works on supported lights with RGB aux LEDs and needs firmware with the feature enabled. My blog post explains the feature and setup, including how to select it without resetting your settings.
Do you find this useful? Can you think of other uses, or similar ways to improve Anduril? I’d appreciate your feedback here.
Firmware download: Voltage Colored Number Blinks release
I think the feature you added to offer POVD color blinks for Batt Check is a very good idea
it is based on 2026-08-12..
if you update it to be based on 2026-09-12+1 I would be interested to know you did that
I hope ToyKeeper incorporates your idea to offer POVD color batt check blinks, into her future Anduril builds
The reset clears your settings and your thermal calibration, so write down anything you want back before you flash.
I use a flowchart to annotate all custom eeprom options, so it is easy to know which commands to use to reconfigure them, and to remember which things to change.
I find it important to include thermal calibration and battery Voltage calibration after any reflash. I use an IR Thermometer to check the temperature of the light, and a DMM to check the Voltage of the battery.
This is my Options list for a KR1AA:
