The Acebeam L19 v2.0 a very long-throwing hunting flashlight, featuring a TIR lens for maximum throw with minimal spill. Powered by a single included 21700 battery, the light features dual electronic and tactical switches. Very distinctive build, as you will see in the review. And the performance?
Why do the L19 have a slow taper downward on the runtimes versus the P17? I thought the draw to the Acebeam was their flat output drivers but this doesn’t seem to be the case. High and Medium sea to have a flatter output and a quicker drop off so is it heat related?
Those 50.3 and 70.3 lights use boost drivers, which can offer a better stabilized output. Coupled with the fact that 70.3 is a lot more efficient than SFT40 (or PM1), they have a longer, flat output than the SFT40 thrower.
Buck driver can provide stable output, as long as Vbatt is higher than Vf + driver voltage drop (which is usually substantial, like 0.2 - 0.3v). Below that there is no regulation. The higher Vf an emitter has, the worse it will perform with a buck driver. At 8A output, PM1 needs Vf of 3.6v and SFT-40 needs Vf of 3.45v. As a result the SFT-40 version of this light should have longer stabilized output.
Hmm…
That’s something that I suspected.
What would be nice is a bright & throwy emitter that is about as efficient as an XHP70.3 HI.
I guess CREE would have to make it.
