Hello guys, I have more lights than I ever need and I’m only comfy gifting mid-powered [regulated] lights to friends / family (you know, ones that won’t overheat and burn their hands in seconds).
I have 4-5 lights I’m not comfy giving to non flashaholic, either they’re to hot or to complicated so I’m listing them here for best offer. Ones that don’t sell will likely be future GAW lights but I have plenty more hosts to build for that so if you want something now make literally ANY offer!
Solarstorm SC02: Chinese 365 UV emitter on noctogon (this particular emitter performs better than any other Chinese UV emitter I’ve ever seen, and I buy a lot of UV emitters), 5x 7135 driver with Tom_E 1 mode + hidden strobe FW. Hand filed to fit ZWB2 filter.
Fandyfire rook: triple conversion with thick copper integrated emitter shelf. RGB running Dr Jones FW & driver w/ each channel running 2x 7135. Triple noctigon, Ledil CUTE wide optic under glass lens. 14500 only but you can load it out with 1, 2 or 3 14500 with only difference being extended runtime the more cells you run.
Convoy S2+ triple white / UV. Want to EDC a UV light but not give up white light or have to carry two, here’s your chance!
This last one I am putting an asking price on as the labor I have in it was just atrocious building that custom one-off optic setup… It runs 2x LH351D emitters and 1 Chinese 365nm emitter. White runs 7x 380mA 7135’s, UV runs one. It is heavily modified A6 FW with the UV totally hidden from normal mode rotation (step back to UV). See the build and read about it here
I am pricing this one at $55 shipped and considering the amount of time in it its the one I’m not able to do OBO on it [sorry]. Do note the slight color differnce on the 18350 body, I purchased it from Mtn while the host came from convoy direct and the 18350 tube is ever so slightly more gray.
Please excuse the low res photos.
Blue Convoy S2+ SOLD Triple Nichia 319at with the best possible thermal path- spacer soldered to pill, triple MCPCB soldered to spacer. AR glass. BLF-A6 driver with my modified A6 FW. Includes both bodies. Brass button at driver, bypassed spring at tail.
Sunwayman V11R SOLD LH351D LED on 10mm SinkPAD. Centered perfectly (not an easy task lol). Includes AA/14500 extender and metal button cover. Has DC-Fix on lens but it’s easy to remove.
