The good thing I noticed is there's no price increase when choosing the SFH55 or SST-40 so cost is probably low on this, unless it's not a real listing - they don't have it yet, who knows.
Throw taken at 5 meters, just 2 sec pause (not 30): 514 kcd. Expected to be lower but this light did about 1050 kcd at 5 sec pause on the SBT90.2, and for lumens did 6120 at turn on on 30T's.
So compared to the SBT90.2:
Lumens: 6120 --> 10300
Throw: 1050 kcd --> 514 kcd
Both sets of #'s at turn ON.
Amp measurements can be made - easier on one 30T, not so easy on the carrier with 3 of them.
No, not even close. Running cells in parallel lowers the resistance which is why you get and should get a bump in amps, but the bump is not significant, but all depends on the LED's Vf and other resistance factors.
The LED throttles amperage based on it's Vf. All LED's have a rising Vf as the amps increase. So as amps go up, the Vf goes up, further restricting the amps. Basically you would never double amps by adding a 2nd cell in parallel, unless you had intelligent buck or boost circuitry that can handle high amps. Buck and boost driver are relatively cheap except when handling high amps, then they can get more expensive. I dunno what kind of boost circuitry would handle 40+ amps for example. Maybe it's possible but probably gets very pricey, big, and complicated. But I'm not the right guy to conjecture on this stuff.
The beam has no XHP halo effect, but did notice in closer distances, say under 10 feet, the hot spot is consistent white but further out, still indoors, the hot spot has an inner more yellow spot and the hot spot itself get fuzzy around the edges. Focus seems ok because you only see a center black spot under 1 ft or so. But dunno - didn't play with focusing at all.
Oh I thought you connected all three batteries and was taking the current from one of the batteries. Thats the way I was thinking about measuring current from my multicell JKK80. In that case I think it should be close to 3x the single cell measured current right? If the cells are identical.
Ohh, I suppose so in that configuration. With a carrier, think I could measure amps from all 3. Did this before and needed to solder in heavy gauge wires temporarily.
Mounted. The LED+ pad on the LED has a notched out corner which matched the MCPCB. Funny because the SBT90.2 had the notch on the opposite end of the pad, so didn't match the MCPCB (not shown here though):
