Share the latest three flashlight from Lumintop
Lumintop apollo with 4 High CRI LEDs with 5 Power Levels and 2 Strobe modes, reach up to 120 metres and has 4 lower power levels with a run time of up to 6 days (Eco mode 10lm).
Lumintop Petal flashlight has two sources for output, a LEP which is rated to 250 lumens top output, yet it can reach as far as 1056m! Around the LEP are an array of 6 LEDs provide output up to 300 lumens, or in combination with the LEP up to 500lumens.
Lumintop FW21 X9LS is a pocket thrower, a total of 1800 lumens and range of up to 735 metres, a small ergonomically shaped body, with deep grooves on the head to help with heat management and a strong clip
Which do you prefer, follow our Facebook, know more about the latest product
The Apollo looks interesting. First high CRI Osram emitters I’ve seen. The CCT isn’t mentioned though. Odd that basic specs are omitted.
The 10 lumen low and only 1000 lumen turbo makes me think boost driver, so maybe it’s somewhat efficient?
4000k
Yeah that image doesn’t state CCT anywhere, nor is it anywhere on the product page. If there’s a new 4000k high CRI emitter out there from Osram that’d be cool though. There are a lot of multi emitter lights out there and the Apollo’s specs aren’t impressive, but if it’s a boost driver maybe it can make up some points with runtime and efficiency.
Petal looks cool, if available in different materials…brass/copper/titanium/SS/etc
have checked with the manufacturer that it is 4000k
Your idea is good, I think it will be available in the next few months
