@gcbryan, we seem to be having similar problems getting some of our knives sharp. Hopefully sharing my current experiences will shed some light on any problems you are having.
Having always free handing with a two sided stone and steel until fairly recently, I decided to try something different. Here is my observations up to this point. I am definitely no expert. In fact, I am kind of stumbling my way through this at the moment, Here is where I am at.
The best thing about these good quality Chinese budget knives is that I can trial and error some new sharpening techniques without too much fear of screwing things up and I am finding that there are two stages to getting a good working edge on my knives. One is reprofiling to get an even and consistant edge , and the other is general touch up to maintain an edge.
At the moment, I have the Spyderco Sharpmaker and the Smith’s Diamond Precision Knife Sharpening System to attempt to get all my recently bought knives up to snuff.
The Spyderco Sharpmaker works really good and gets my knives sharper than they have ever been if the angle of the bevel is less than 20 degrees. If the angle is above 20 degrees, the Sharpmaker is useless. It just will not remove enough steel to reprofile.
So I have been reprofiling with the Smith’s System on the 20 degrees per side setting. Even with the diamond stones, it took several nights working on my Ganzo G704 to get to the edge. I painted the bevel with a sharpie to monitor my progress and eventually got there.
I have now been working on my Ganzo G707 for a couple of days. I don’t know if my diamond stones are wore out or if the Ganzo steel is just tough. I Have my Smith’s set up for 20 degrees each side, and one edge came from the factory less than 20 and the other side more than 20. Here are some pictures of my progress.
The first pic shows the Sharpie markings at the outer edge of the bevel. It also shows a burr produced by sharpening the other side.
The second one shows the other side of the blade with the Sharpie markings at the inner edge of the bevel.
With the time it takes to reprofile with the Smith’s Diamond System, my plans are to get the Work Sharp sharpener to do my reprofiling and speed things up.
I still haven’t figured out my strategy yet. The Spyderco Sharpmaker has two main concepts. One is that if you can hold the blade straight up and down, you can get a consistant edge angle, and two is to have the edge profiled to 30 degrees inclusive( 15 per side) and then put a micro bevel of 40 degrees inclusive and then maintain the micro bevel at 40 degrees inclusive through the years until you sharpen away the 30 degree main bevel. Then reprofile again to 30 inclusive and then put another 40 degree micro bevel. Rinse and Repeat.
I don’t have any way to reprofile my edges to 30 degrees inclusive. So I will probably end up reprofiling my all my edges to 20 degrees each side with the Work Sharp and then maintain them at 20 degrees each side with the Sharpmaker.
One of the things I worry about with this plan of attack is, doesn’t the Work Sharp put a convex edge on a knife? Will the Sharpmaker mesh with a convex edge? Is it too late to go back to one pocket knife, a handfull of soft steeled kitchen knives, and a whetstone?
Oh, the trouble this forum gets me into.
