Hello there,
I made a new thread for this device so it can be easily found on Google. Here are some measurements with the Snakol SK-8202, for those who are interested.
The device itself is made of cheap plastic, but this is also fairly cheap (40-60 € depending on sales etc). The buttons are extremely loud. It runs on 2*AAA batteries, which from my feeling lasts forever. I still use the first set of batteries.
It uses the well known AS7341 sensor, which is also used in the Opple Lightmaster devices.
It seems to be relatively accurate, at least as long as light is falling vertically onto the sensor from above. If this is not the case, there could be huge deviations in the measurement. If in doubt, this has to be checked with slightly moving the device and checking for changing values (CRI ± 5 or more). In addition, warm light sources (in some cases even those with a specified 2700 K) cannot be properly measured, as the device can only measure down to 2500 K, and up to 8000 K, which can be exceeded by standard cool white LEDs very easily.
Furthermore, you should not move the device and - more importantly - wait a few seconds (at least 5 seconds) until the values have stabilized, as there seems to be some kind of measurement averaging function built in.
Sunlight is measured very well.
Especially cool white low CRI light sources are also measured well. The CRI rating is precise (± 2).
Colored LEDs are not measured well (understandable).
The Optisolis mix was measured CRI 98 with spectrometer.
Even LEDs with KSF:Mn4+ phosphor are measured somewhat correctly:
If this device were sold by a reputable and, above all, customer-oriented retailer, it would be highly recommended. However, I cannot really recommend it, as the customer support is really unacceptable (described here), especially since they advertise “great support.”
So I will not recommend this device due to very bad customer support. I don’t want to support these companies with this behavior. Who doesn’t care about this, could be happy with this device since it is able to give a first rough estimate for the light quality of white light.
Thanks for reading!
