Short Review - Utorch UT01 - AA - 4 modes - side switch
utorch UT01 - AA - 4 modes - side switch
pluses:
very small - mostly due to side switch (though the reflector could be shallower),
4 modes instead of 3,
light a nice neutral color, no color artifacts
no memory [starts on low]
3 blinky modes instead of one (not that i ever use them but still, not a useless feature )
frequently on sale for $10
beam is a good balance between hotspot and floody
tailstanding is easy
clip can reverse (body can also reverse) so you can find the side switch easily
minuses:
switch is rubber, not metal,
longish press for off,
low is 3 lumens, not a moonlight (<1)
no memory (can;t decide if i like it or not, the astrolux lets you set memory on or off)
blinky modes (sometimes like them, sometimes do not - at least these are fairly easy to avoid)
anyway i really like a very small, multimode light
i’m going to try shifting away from my former EDC for a while (astrolux S1) - to see if small makes up for brightness and run time
it might!
i did not try
  • waterproofing, beam shots, drop tests, power measurements, run time, or lumens, or 14500 battery - just NiMH enerloop
wle
It has memory. Long press from off returns to previously used mode just like Manker E11.
Also, settings can be adjusted to preference. See here:
https://budgetlightforum.com/t/-/45752
yes, thanks, i discovered that later, or someone told me
even better!
great 1xAA light
[[actually long press from off returns to last mode - UNLESS last mode was ultra-low, then long press from off goes to low - which is actually what you want it to do, or at least i am happy with it]]
wle
