Wurkkos TS32 Short Review
Reviewer's Overall Rating: ★★★★
"TS32 Pictures":https://imgur.com/a/pvZkiC6
Wurkkos TS32 Specs & Measurement Information
Emitter(s): 12pc - LH351D (flood), 1pc - SFT40 (throw)
Price in USD at publication time: $85.99
Cell(s): 3pc - 21700 Molicel P42A (utilized for the review but not included)
Waterproof Rating: IP68
Switch Type: E-Switch
On-Board Charging? Yes
Charge Port Type: USB-C
Measured CCT: 4800k (flood) 5800k (throw)
Measured CRI: 95.3CRI (flood) 66.5CRI (throw)
Claimed Lumens (lm): 13,000lm*
Measured Lumens (at startup): 13,210lm (flood) 1830lm (spot) 15,040lm (flood + throw)
Measured Lumens @ 30 seconds: 11,900lm (flood) 1700lm (spot)
Claimed Throw (m): 530m
Claimed Candela (Kcd): Information not published
Measured Throw (m): 329m (flood) 625m (spot)
Measured Candela (Kcd) @ 2 meters: 27Kcd (flood) 97Kcd (spot)
Wurkkos’s specs seem to vary from website to website regarding what their claimed output(s) are for each variation of the light. My measurements are taken using high-drain cells with a lumen tube & Sunche meter.
Pros:
- Utilizes 3pcs of 21700 cells (can utilize flat or button top cells)
- Flood & Throw channels can be used simultaneously
- USB-C Charging Powerbank functionality
- Flat-top battery adapter included UI is adequate - ramping is smooth (literally and figuratively) Does not heat up as quickly as the 519A emitter variant
Cons:
- Lacking thermal mass
- Charging protocols are dated (slow)
- Output steps down fairly quickly
- Emitter choice gives you a greener tint than the 519A variant
Summary: ★★★★
I purchased this light under the premise of a dual-channel, high CRI light in my favorite form factor, the "soda can" style. The CRI measured at 95.3CRI. The CCT measured in at 4800k on my Opple Light Master Pro. My eyes see quite a bit of green tint within the lower output levels, but this lessened as I ramped upwards. This is commonplace with the LH351D emitter. The output doesn't drop significantly during the first 30 seconds. After 90 seconds, the light becomes warm but not uncomfortable to hold. Beyond 90 seconds, the output drops quickly but stabilizes at 1,530lm. At the five-minute mark, the light is borderline hot, and the output has decreased to about 1,500 lumens but appears steady. At the 5 min mark, I concluded the test.
The build quality is average. My light doesn't have some of the issues I've read about in other reviews, but it isn't high-end either. The USB-C port and onboard charging work, but it would be nice to see QC or PD protocols supported. I illuminated some white antenna housings on a skinny communications tower at 500 meters in urban lighting using the throw channel. The UI is one of the better UIs I've experienced with dual-channel lights. The default on my light is smooth ramping with instant access to Turbo (double click). At this light's price point, it is an excellent general-purpose light. The ability to switch from flood to throw or utilize them simultaneously is a positive.
Disclaimer: This light was not provided to me by any entity and was purchased utilizing my own resources. I have not been paid or otherwise compensated in any form to review this item, nor have I been withholding any problems or defects.
