Very carefully ![]()
I don’t like ano damage.
“How do you hold your side switch flashlights?”
If my right hand is occupied then I hold it with my left hand.
If my left hand is occupied then I hold it with my right hand.
If both hands are occupied then I don’t hold it at all.
Hope this handy guide helps any of you having trouble holding your flashes especially side switch ones.
WTF. ![]()
Depends.
Not very but thats part of the potential dropping problem.
Concrete is very rough :cry:
“Depends”.
Ok tell us how ya hold your Depends?
I hold em’ between my index finger and thumb farthest away from the soggy parts. Arm fully extended.
Bort:
CRC:
Bort:
Very carefully
I don’t like ano damage.How rough are your hands??
Concrete is very rough :cry:Lol, I knew what you meant, I was just intentionaly misinterpreting it
I successfully threw you off the scent from my metal bending superman strength grip ![]()
Side switch under my thumb, lens pointing forward away from me
“Side switch under my thumb, lens pointing forward away from me.”
Appreciated how to. I was wonderin’ why my side switches were illuminating only my a*s.
Ya really learn somethings here that ya could never learn on your own.
That is a very interesting light you have
Thank you. I built it
I have a few projects I am doing here while practising Stay-At-Home as requested by the NM Governor. Making some picture frames, doing some renovations to my converted cargo trailer camper, taxes, and other fun stuff. I decided I would work in a flashlight build. I am using parts that I have on hand. Some I have had for a while, like the 3 volt XHP50.2 and the lexel driver pictured below. The XHP50.2 is one of several I bought when they first came out in 3 volt versions. It is on a 16mm Noctigo…
The tail switch is a much better choice. I know this wasn’t your question but reconsider your objectives. The gas petal is always to the right of the brake for a reason.
For side switch… usually fingers down, thumb up to operate switch, & light pointed away from me.
Is their any other way???
For the FW3A, other tube lights, & C8 size lights with a tail switch I use a “Cigar Grip” to activate & toggle switch. Then many times I will transition to the grip mentioned above.
Side switch lights like purse! Real light have a tail switch, so you can hold it like a man.
“Depends”.
I can’t impossibly hold it with just two fingers.
Reverse (icepick) grip all day, unless the light is uber-tiny like the Olight S1. Then I pinch-grip it.
Handshake grip with thumb on the button. Lens at the front.
I hold mine sideways, gangstah style.
It looks so cool…
It looks so cool…
Dangit, beat by Lightbringer.
I was going to say I hope it like a Glock with sights on the side of the slide. Not enough “O’s” in coool…
Wolf spider eyes. Showed that to a neighbor one night while we were shooting the breeze. He walked on the pavement going back home!
thumb on the side switch///
(not “COP CARRY”)
’’[[why do they do that?]]”
