I was in the market for a new charger recently, and decided to try out Liitokala’s Lii-600 after using their Lii-500 for so long.
The temperature sensors, wider range of charge/discharge rates, and ability to accommodate 4x26650 were all nice new features.
But…there was one feature that bothered me immensely, with every button press and charge completion.
The beeping.
Oh, the beeping.
It would’ve liked a silent mode for this charger. No matter, though!
I decided to crack open the charger and silence it myself! All I needed was a Phillips screwdriver with a narrow shaft (~3mm).
Step 1: Remove the back
- There are 7 screws to remove - 4 are under the rubber feet
Step 2: Remove the main PCB
- Unhook the springs on the battery slots
- Lift the PCB up and toward the side the display is on - there’s a ribbon cable on that side
- No need to unhook the ribbon cable - it’s long enough to not get in the way
Step 2a: Check the temperature sensors!
- While you have the charger open, check the angle of the temperature sensors on the other side of the circled area
- I found 2 of mine were bent downward, and not properly sticking up into the thermal paste below the metal plates
Step 3: Remove the control/display PCB
- There are 6 screws to remove
- The display is only attached to the PCB by a couple wires, so don’t be surprised if it drops as you lift it
Step 4: Disconnect the piezoelectric buzzer
- I just added a circle of paper in case I change my mind later
And that’s all! Afterward, just reverse the steps you did and the charger should be good to go.
Remember to be gentle when replacing the screws, since they can strip the plastic hole easily.
