Simple light box and photo editing - how to (picture heavy).
In the past I’ve had quite a few people PM or ask in the forums how I get the images how I do, so here I’m going to show the basics of how I do my own.
I took these pics as I was setting up a light box to start a review and though I would get this done at the same time if anyone else wants to try their hand at it.
Usually when I am doing reviews I will use my digital camera, but for this tutorial I just used my mobile phone to take the pictures to show a good camera isn’t needed.
Before I start the how to, here is a quick picture of the finished product.
This was just a rushed job, here is how it was done.
Here I just started with a small box, use a bigger box for bigger items.
Then you need to cut a hole in the top of the box, if you wanted to go all out you could cut holes in the sides for extra lighting.
The hole should be smaller than the piece of paper or whatever else you will be using for a diffuser.
Some standard tape and A4 paper
Cover the inside of the box with white paper.
First I had covered the bottom of the box with paper, then at the back of the box I have used a piece of paper taped to give it a gradual curve to cut down on sharp lines that can cause shadows.
I taped some polystyrene to the box at first, this wasn’t such a good idea as it blocked a lot of light.
Here there is some A4 paper taped over the polystyrene with a light on top to illuminate the inside of the box, but ideally you would use some kind of adjustable lamp. Or if you had a few adjustable lamps they could be used on both sides and from the top.
As you can see, there isn’t anything fancy going on inside of the box.
You can see where the lines in the paper are, don’t worry about it too much but just try to smooth them out a little.
Place the item you want to take the picture of inside the box, I could have lowered the paper at the back of the box so I wouldn’t have any line in the image but I took the picture like this so I can show how the lines are removed.
Open your image in Photoshop (I use CS6), you should then go to “Image > Adjustments > Levels
The slider on the right should be dragged to the left until its on the left hand side of the bulk of blackness.
You can see the new positing of the left slider and how the image has changed, you dont need to get rid of all the black lines in the image with this, just enough to make the background look pure white.
The middle slider can be moved to the right a little to cut down on the high contrast a little and the slider on the left can be adjusted to make dark colours darker.
Click OK then select the solid paint brush and use white to erase any dark lines left over.
The lines are gone and the bottle appears to have no background.
This was a little rushed but I could have adjusted the levels to bring back accurate colours of the bottle although it slipped my mind at the time.
And just another quick one while I was at it of some post-it notes.
And after.
I forgot to mention that you should adjust all your image sizes to a acceptable resolution, I usually save mine between 500-750px wide and when I save the images I use “Save for web” under the file menu to reduce the file size so it doesn’t take 5 mins to load a page with a lot of images.
I hope this helps anyone wanting to make their own clean images similar to this, there is also other ways to get the same effect but this is how I have been doing it for about 2 years or more.
If anyone is having trouble and needs help or has questions etc I’ll try to reply to this thread to help you out.
Thanks for the tips ezarc.
Thanks for the tips. I’d suggest you to use the percentage option when posting the pictures in the forum, they are out of margins when I see them on the iPad
Nice…thanks!
What kinda camera do you use?
And/or recommend for “budget” minded folks?
And have you ever used Gimp?
No problem.
I like your outdoor shots (I like the ones I’ve done too) but its not often I have a good opportunity to do them as I live in a small apartment and its a hassle taking all my gear to someone else’s place to do photos for a review.
The light box is nice for clear for pics as indoor pics always turn out pretty bad when I have tried them.
I’ve noticed that on my Nexus 7 too but I didn’t really think of it when posting now, for my computers and laptops its also good.
I’ll adjust them to a percentage later as it will take a bit of time to go over every pic again.
The camera I used for this was just a Motorola Moto G, which gets a lot of bad press for taking bad pics but I think it takes good pics in full sunlight and brightly lit areas.
When I do reviews thou I usually use a Kodak Easyshare Z981 that I bought for about $70 or something from eBay. It’s not great but its a better camera than my phones.
I used to use Gimp a lot years ago and preferred it but I’ve lost the hang of it now since I haven’t used it for about 7-8 years.
Thanks for the tutorial, your set-up is simple and very effective.
In my appartment I am allowed 1square meter for my hobby, so there is even no space for such a photo-box
I agree with using the phone camera, nearly all pictures I post on blf are made with my phone
You pick up a collapsible light tent from ebay quite cheaply - a small one would be about 40cm (16”) square, and would fold down flat for storage.
These tend to be what I use for ‘product’ shots - and the translucent sides allow for creative lighting.
A white bath makes a fairly decent backdrop. Lighting is a little tricky, but not impossible.
Don’t change them now, the suggestion only affects future posts! They are not that bad, just a bit. It’s not one of those situations when someone uploads a 2374 mpx picture and the forum nearly disappears
