What would be the simplest way to reduce the outer diameter of a small length of copper tubing, without use of a lathe (and with minimal special tools, etc.)?
You can cut down the length of the tube with a saw that will take out some material (e.g. hacksaw, saber-saw, saws-all), then compress tube until gap is gone. If more material needs to be removed, use a double-sided file (will keep joint a perfect match). Once to the correct size, solder the joint and then file of excess solder.
(don’t laugh) I’ve been putting the cap into a vise and filing it then rotating it, but it’s taking forever. I have a Dremel, but can’t figure how how I could leverage that to maybe spin the tubing or something like that, so I figured I’d pose the question.
I actually also have a drill with a 1/2” chuck, but that piece is a cap for 1/2” pipe/tubing, so the OD of the cap is slightly larger than 1/2”. In other words, the cap won’t fit into the 1/2” drill chuck, so I’d need to get a larger than 1/2” chuck?
Try this, Whittle a piece of wood/ dowel to fit. Get a nice snug fit.
drive a finishing nail (has no head) into the wood,chuck nail in drill.
Staple sandpaper to board, bring spinning pipe cap in contact with sandpaper.
(high speed not recommended) WHERE SAFETY GLASSES!!!
How’d you know I had a piece of 1/2” pipe :)? Turns out I picked a 2’ piece up at the same time as the cap… but, unfortunately, the pipe won’t fit into the 1/2” chuck (chuck’s too small, or pipe is too big, diameter-wise.
But, that did give me another idea. I put the cap on the pipe, and am sanding it the cap that way, and seems to be working better than with the cap in the vise. Slow, but I think it’ll work (eventually).
1/2" wooden dowel, file down one end to fit your chuck. It doesn't have to be round, file 3 flats on it to make it triangular. Put the cap on the other end and soak it in water to swell the wood so it holds the cap. When you're done dry it out to release the cap.
1/2 rubber well plug/nut http://www.fastenersplus.com/products/rubber-fasteners
Tighten the bolt rubber expands. We used them to attach truck mirrors to the doors.
If you caught the mirror it would pull off without destroying the door
Best sources : Farm store, good hardware ACE etc. Auto parts that does a lot of autobody
supply.
You could put the dremel in a vise, if you have one, (so it's sticking out flat) and then use the dowel trick, or the pipe, to hold on and run the cap against the dremel. It's one of those things where it takes some time doing it, to master it.
