One’s application is critical to consider.
Example: I’ve got some old-school Emisars - a D1S and a D4 with a frosted optic.
- D1S
- Single-LED
- ~50mm reflector
- Throws handily to >300m
- Intense hotspot that positively drowns its spill light
- D4
- Quad-LED
- ~10mm frosted quad-optic
Throws Brute-force floods to ~30m, briefly
- Wide beam with gentle falloff to is spill
The D1S will run flat-out for long periods of time without overheating because it’s 25% of the total power going into ~1000% the thermal mass. This is necessary because it’s only useful at medium-to-long distances and thus normally runs at 50-100% power all the time.
The D4 will throttle down in ~20s when run flat-out because it’s 400% the power of the D1S with ~10% of the mass. But it only needs to illuminate to some ~3m >95% of the time so it’s normally operating at perhaps the highest regulated setting.
The D1S could switch-hit for the D4 with bolted-on diffusion of some sort - but physics is a harsh mistress and it would require similar¹ power to illuminate the same area at the same intensity. Conversely, even a narrow quad-optic won’t bring the D4 into the D1S’s throw category
¹Actually slightly more power because that single LED would need to be driven harder than the D4s quad LEDs and we’re assuming no significant losses to the additional diffusion
The TL;DR: A single LED with a big reflector or optic is the choice for throw. For flood usage a triple or quad may be a better option, specifics depending.
EDIT: Comparison photos for funsies!
Throw
~50’ / ~15m - not the best distance for comparison but it’s what was available this evening as I was walking the dogs.
D1S
D4
VICTOR: D1S
At this short distance the D4 can reach the target easily enough, but at the expense of considerable foreground illumination which the camera compensates for better than the eye. At but double the distance inverse-squared markedly reduces the target illumination and it’s nearly useless. The actual intensity on target at this short distance is also lower.
Flood
~3’ / ~1m - a somewhat typical task light distance.
D1S
D4
VICTOR: D4
It would be annoying to sweep a ~6" / ~150mm wide path back and forth to look for leavings with the D1S, whose intense hotspot causes the pupils to contract more than the camera’s exposure trickery suggests. Also, the D4 is easily pocketable while the D1S is at best a jacket pocket light.
