Single sided two channel 7135 only?
Looking for a single sided 17mm 3x7135+1. Does it exist?
RMM’s moonlight special?
Would probably need removal of some 7135’s and I can’t see from the pictures on the site if there are any other components on the battery side. Would also need custom firmware if you’re looking to drive 2 LEDs.
The moonlight special is an 8 chip driver. I could get the kit with 6 chips and double up two on the mcu side. But was wondering if anyone had done a single sided board with a larger B+ pad than the MS driver has. Edit- not for two LEDs but a triple with A6 firmware and 5+1 instead of fet+1.
I made an Oshpark board a while ago
HQ4D
Cool, it looks like the single 7135 is on pin 5, same as RMM’s moonlight special so I can order the chip from him flashed with TK’s A6 firmware.
Yes, pin 5 drives the single AMC7135 (Q1) and pin 6 the other 3 (Q2-4). Using the preflashed MCU should work. Perhaps the mode spacing is a bit off. But LVP and BattCheck should be ok, as I too prefer R1 behind the diode (classic nanjg design), which makes for a 0.25V offset.
