Yesterday I was doing some run times test for AA batteries stored for 2 months after charging. I was comparing a Tenergy Premium and a 2nd gen Eneloop. I was using a Sipik clone, UltraOK, on high. This particular light is one mode, and I have used it for a few months to run similar tests. When I operated it with the Eneloop after about 30 minutes it began to blink for a few seconds, and then stop blinking, and start again. This went on for about a minute or less, and settled out.
In previous tests of run times with the Eneloops here are the results. After one week *1hr 32min. *After one month 1hr 58min. Yesterday 2hrs 42 min. I repeated the test with similar results. This time is certainly an anomaly, and I am wondering if even though this light is a single mode, could the blinking have been the result of the circuit changing to a low mode like a 3 mode Sipik?
Previously using a 3 mode Sipik on low the Eneloop lasted 3hr 49min. Since the time of 2hrs 42min is close to the mid point between the low and high times (1hr 32 min and 3hrs 49min) it makes sense to me that the light somehow went into a low mode. However, I have no idea how the circuits within the light work.
Maybe it's a morse code message from the programmer. Or, maybe you can select a different mode group during or shortly after the blinking. Seems unlikely, but may be worth trying out.
Did it stay messed up after that? (With another cell.)
If you post a picture of your driver board (component side) it might be helpful. To me it sounds as if the driver is failing. Was there any rhyme or reason to the blinking? (or was it more like a flicker or something)
It sounds to me like a component on the driver is slowly failing and therefore increasing resistance in the circuit or reducing current draw, thus increasing run time.
More like a flicker. I have tried it with another Tenergy and a Duracell ion core and it works as it should. I’ll see if I can figure how to get a picture of the driver board.
Thanks,
Jerry
> It may just be a weak ground between the driver and pill.
+1, had that exact symptom and that was the problem, cracked solder that never quite stuck to the aluminum anyhow.
Cleaned it all up, soldered a little bit of copper wire to the driver after hammering it flattish, wrapped it around the edge of the driver where it was going into the pill, and squoze the driver into place and that solved that for the meanwhile.
Check the very center of the bat + down inside the battery tube…sometimes it get’s some sort of black goop on it right where the + side of the battery touches the copper ring…causing high resistance…usually resulting in lower current draw
Get a q-tip and some alcohol and scrub it clean…then try again
This is why when I open up my sk68’s I run a thin layer of solder over that center pad…(might just be making it worse though)
Several people make assembled BLF 15mm drivers that just drop in — if you ask someone will speak up;
all you need to do is solder the wires to the 2 spots on the emitter connection.
Or — depends on whether you have the rare solid pill surface under the emitter, or just a hole between driver and back of the emitter — lots of good possibilities for improving the LED, putting in a color emitter, etc.
Don’t toss it. It’s an opportunity (for someone anyhow)
I cleaned It with alcohol, put it together and it seems to be working OK now. I depleted two Eneloops and they worked as expected. Thanks for the help.
I tried to get a picture of the component, but my camera would not focus closely enough to get a meaningful photo.
I have used this and one other single mode clone to be as consistent as I can, although there is probably not that much difference in these lights.
