The driver is too big to fit in the pill but it will sit on the top of it and the pill screws down on to it , makes it a bit tight in the battery compartment the switch won’t screw down the last half turn
but it all seems to work ok and now the medium is the same brightness as full was before and full is much brighter , better than its big brother SK98
Only downside so far is damn it gets hot fast on full now might have to treat full as turbo and medium as full the qlite driver has a nice low mode now and no stupid blinkies.
Thats my experience, want brighter, gets hotter, so run on medium.
What seems to work well is to skip the fancy upgrades, get a 3 mode and drop in a lithium cell. Bright enough, fine on medium, just needs some caution to notice when the output drops as the cell discharges.
A single 14500 or AA put out enough amperage for a 105 qlite driver to push a XML? I am asking because I was looking at these boost drivers : https://www.fasttech.com/p/1127407 thinking this was about max a 14500 or AA could muster, but if you can fit a xml and 105 qlite heck I’ll try it!
I have gotten over two amps with an IMR 10440 directly driving an XM-L. A good high discharge 14500 won’t limit the output. It depends on stray resistances like the spring, lead wires and maybe the 7135s themselves. For AAs, I like SK-58s better, at least if you don’t use primary lithiums. All that metal is not needed with lower currents, though it does improve efficiency some. (I don’t choose those smaller zoomies like this one 3-mode Zoom AA/1450 EXPIRED ! "Black" $1.99 Max 3ea for esthetic reasons only.)
The last “upgrade” i did to a SK68 was this.
(the silver one on the left was an SK68 like the right one before i started.) its one of my current EDC lights.
Yes the 14550 I have works ok with, not tested run times but I can’t leave it on high for long anyway as it gets damn hot
I use a Trust fire flame , I changed the LED to one from a Fandyfire Warrior(XML-U2) quite a cool tint replaced the driver with the Qlite , snipped a couple of turns off the spring to make battery cap fit better then braided driver and tailcap
In the photo to compare is a ZeusRay zoomie with XML2 and quite good reviews, mine has had driver and tail cap springs braided as well which is on the left
On the right is the SK68 , both were on full but piccy taken with my iphone which cut the white balance right down it looks much brighter in person but at least you can compare with the other quite well known Zeusray, the SK68 matches the brightness but can’t flood out as much or zoom in as small as the Zeusray but as a EDC its quite a good bright torch.
