Can you test with a +10A power supply or +4 x 18650 cells @4.2V? Thanks for the schematics above. Now I wonder if all SRK’s deliver an unbalanced load to each emitter, regardless of the 6.5A draw from the cells. Im waiting on sinkpads before I pull mine apart again. At that time, I can test current to each emitter. Anyone else able to do this now?
I guess we could block each emitter/reflector with cardboard & tape and compare lux between emitters as another way to roughly estimate.
That 7135 master/slave setup is sounding better all the time…
Fandyfire UV-S5 (link) does 7.19A w/4 cells, and 5.30A with only one(!). As far as tearing it apart I'm in the same boat, waiting on copper. I finally found 3 more 15k '153' resistors on an old dead video card, though.
Speaking of waiting on copper, shouldn't they be done any day now? It's been like 3+ weeks, hasn't it? It... it hasn't? Maybe the calendars are wrong...
They are 15k. While I had the hot air going I harvested any that had 'interesting' numbers, all the others were completely not what I thought they would be but the 153s are indeed 15k'ers.
Haha, yeah, how about the ones that still look like valid characters even when they're turned wrong side up? xD
I reeeeally need one of those nifty magnifying desk lamps, 'cause trying to hold a flashlight and butane torch AND a loupe in one hand while the other hand does grain-of-sand-resistor plucking... you know, I think I'll go prowl ebay right now as a matter of fact.
Would it be possible to calculate the Vdrop before the current sense resistor, and then Figure out what each of them needs to be to get 2A out of each xml? I wonder if anyone here would be able to put together a better driver for 4paralell X18650 as it looks like most of them have fairly interchangeable parts.
There are a fair number of drivers out there that'll run 3 XM-L wired in series, but the sticking point is the SRK's electronic switch. Finding a driver for an electronic switch, AND 3x LEDs, AND more current per emitter than what the stock driver does, is, I think, pretty much impossible. Though I'd love to be proven wrong!
CRAP! I thought I had '153' resistors, but when I snapped some macro pics so I could actually see what I had been working on, looks like I got something mixed up and stacked on some 'ESI' resistors instead!
Its all good comfychair. These resistors have a mercury switch in them that allows them to run as ESI resistors up one way and turn the light over and they work as 153 resistors. There will be a problem though if they are mounted in different directions. You will have light coming out the tailcap if this is the case.
