Skyray King replacement glass
I dropped my Skyray King and broke the glass lense. Anyone got a link to a replacement lense?
Thanks E
IIRC it real SRK’s use an extra-thick lens around 55mm in diameter. 55x3mm sounds right, CNQG has AR lenses in that size here: http://www.cnqualitygoods.com/goods.php?id=1970
Thanks man I appreciate it.
You’re welcome. Do realize that 3mm is pretty thick! CNQG warns that some clones have 2mm. I’m not sure, but I heard that most clones have 2mm. You can possibly remove the o-ring or switch to a thinner one to make it work, or maybe just squeeze it in with no problem.
I don’t have a lot to measure or compare, but I do have a Securitying light here from MTN Electronics and that does have a 3mm lens. So we know that all clones don’t have 2mm!
I have also heard that the 54.87mm x 2.25mm UCLp lens from flashlightlens.com fits.
Then choose the lens size and thickness from the drop down menu. This is an anti reflective coated plastic lens which should actually increase true OTF lumens output by a measurable amount.
Hi Eric. I hope all is well. A shame about the broken glass. I dropped a shocker the other day and smashed it as well.
Hi Eric. I hope all is well! +1
Thanks guys, I’m doing ok.
Same thing happened to my SRK …
From my “SRK broken lens” thread a while back … :
I got the UCLp AR Acrylic Lens from flashlightlens … it’s perfect.
Good to see you and I haven’t been around myself but I have a non AR coated lens for you.PM me if you are interested.
PM sent to DARCANGEL thanks
