Hi to all,
Im new here, hoping to find an answer to following problem with my Astrolux C8 XPL HI. It has the BLF A6 driver. While stepping up the modes, it works flawlessly, short click leads to next higher mode.
However the backwards switching from higher to lower modes is very sluggish. The “medium” click sometimes takes up to 2-3 seconds which i find quite annoying, especially when I compare it to performance of the Astrolux S1 which has the same driver inside. There the switching works perfectly, with almost immediate response.
I noticed that the C8 performs significantly better when it gets a bit hot, which makes me believe there is some heat sensitive electronic component inside. Any idea what could be done about it? With the Astrolux S1 i did not experience such issue at all.
