Pete7874
(Pete7874)
September 8, 2024, 11:16pm
1
Looking for a flashlight based on the following requirements:
slow flashing mode: 1x per second ideally, but no more than 2x per second
small form factor, so either AA/14500, 18350, or 16340 battery
not a headlamp
the cheaper the better
I think OTR M3 Pro has it (they call it beacon mode). Just wondering if there are others.
Thanks!
Thanks!
Can andruil 2 ramp the strobing speed? If so that might be your best bet.
Pete7874
(Pete7874)
September 9, 2024, 3:19am
3
It appears that it can. I might look into getting a Sofirn SC31 Pro with an 18350 tube. Thanks.
mcjtom
September 9, 2024, 12:34pm
4
Wurkkos FC11C seems to have 1 Hz beacon, and can be shortened to 18350, but the access to the beacon mode is a little indirect: 3 clicks from on or off to Strobe + 2 clicks to SOS + 2 clicks to Beacon.
Wurkkos FC11 – one of the most recommended flashlights in the past four years. And now it got upgraded with a constant current buck driver and a Nichia 519A! Let’s take a look at the Wurkkos FC11C.
You can find the German version of this review on my website: SammysHP Blog › Wurkkos FC11C
The flashlight was provided by the manufacturer for this review. Thank you very much!
[image]
Overview of hardware
You get the same parts in the box as with the previous FC11:
Wurkkos 18650 Li-ion battery…
Pete7874
(Pete7874)
September 9, 2024, 12:49pm
5
mcjtom:
Thanks. Yeah, even with Anduril 2, it appears that access to beacon requires similar number of clicks. Not a deal breaker though.
Does that Wurkkos one use Anduril 2 nowadays, or still some custom firmware?
Pete7874
(Pete7874)
September 9, 2024, 3:34pm
6
The reviewer mentioned “beacon (a short and bright flash every two seconds).” I wish it was 1 Hz.
Mandrake50
(Mandrake50)
September 9, 2024, 3:44pm
7
OOOPs, I guess it is not Andruil… A light with Andruil could be set to one second…
hIKARInoob
(hIKARInoob)
September 10, 2024, 9:39pm
8
Not exactly the cheapest, but I’m a big fan of the Nitecore LA10 CRI. Clean UI with L-M-H-beacon, and the beacon is once every two seconds. Magnet in the tail. Love it!
In Anduril the default beacon is 2 seconds…
I changed it to 1 second for this test:
the light is a Sofirn SC21 Pro , uses 16340, has built in charging, and tailmagnet.
Pete7874
(Pete7874)
September 11, 2024, 1:58am
10
Thanks. I guess I should have been more clear: I don’t want it to be less frequent than once per second. Between once per second to 2 times per second would be best.
Xtar SD1 is a beacon marketed for diving, might be what you’re after?
