Small form factor red led light?
I have several red LED lights based upon the WF-501 host that I mount on top of a light airgun for shooting rats on a farm. I would love to find a smaller package to save weight and bulk…ideally something that runs off a single AA / AAA and has a smaller body.
I don’t need a lot of throw as I’m only illuminating out to 15 yards. I run it for 2 to 3 hours straight but swapping out a battery once would be fine if it came to that. My Princeton Remix headlamp (http://www.princetontec.com/remix) has 3 red leds and is not powerful enough - I mention this just as a comparison although I don’t know the lumens while running on the red led. So I need something at least 150% as powerful as this headlamp.
Does such a product exist?
I’m wishfully thinking of something along the lines of my Uniquefire OSRAM light…just with a red LED.
ledsupply.com has several different red emitters (on stars), e.g.:
http://www.ledsupply.com/.search?results_page=..%2Fsearch_results.php&query=red&name=Search
http://www.ledsupply.com/indusstar-1up.php
You could probably mod an appropriate light with one of those.
What about 16340 powered lights…standard driver size and easy to mod…
http://www.fasttech.com/product/1198401-ultrafire-602c-diy-led-flashlight-host-with-switch
I have a i3 with red LED and it was kind of hard to swap the led, and it is like the most AAA lights a twisty which is not so perfect for gun mount…
I used this LED http://intl-outdoor.com/cree-xpe-red-led-16mm-mcpcb-p-597.html
This AAA looks modeable and is not too expensive…
http://www.fasttech.com/products/1601/10005144/1403902
If twisty is ok a small AA light in which you can easily swap the LED is the thrunite saber 1A or a clone of it…(fasttech sells the spirit for below 20:money_mouth_face:
And as we are here in budget light forum, the cheapest solution is the wallbuys 3$ zoomie, I don’t have one yet but it is super cheap so it should be no fault to order it and swap in a red LED…
man the drug addict crackheads are getting desperate
if you don’t mind modding a flashlight i think the xp-e Werner linked to would be a great led to swap to. and then either use a host you like, or try the wallbuys $3 flashlight.
otherwise i haven’t seen many flashlights with a red led for sale.
i’ve ordered an AA host that i haven’t received yet; the torpedo:
Hank from intl-outdoor said that a AA/14500 driver and an xp-g is included in the kit, so then it’s more like kit than just a host as it says on the website.
i’m thinking about equipping it with a red xp-e that i also ordered.
U can modify your “LED light” so see this image and i think u like this also u can increase its range as u like.
Tank007 makes a 1aaa with an osram red led. Bright for its size
Edit: mine is labelled BlackCat
Has a cheapo AAA red light come up? the sk68 for 5 bucks is great, but i’d like something less strong for tent use
edit: mhm I could look for a low-power driver for the sk68 too
