Hello.
Did you see THIS one?
Looks somehow like the Sunwayman C10R right?
Is this a new light or is it just too crappy to find some info about it?
Do you think it is worth trying it and is it possible to upgrade it with a better LED?
Hello.
Anyone?
I don`t know either, but that was the exact same thought I had... hey.. that looks like a SWM C10R.
Maybe worth trying out.. not sure if sb already did a review on it.
$10 is not a lot of money ...dont forget the coupon
yes, I saw it!
I think it’s a new model… :exmark:
Which code works for banggood? I might give it a try.
What´s that small plug? Is it for directly charging batteries?
Nice find. Im quite tempted to pull the trigger. *drool*
Its a Small Sun. Normally all of those lights are easy to take apart. As can be seen on the product shots. Retaining ring holds the driver in place.
Bezel probably holds the reflector in place. Probably quite similar to the ZY-T11 and ZY-T29 otherwise, just smaller. New emitter + drjones driver= awesomeness..
If the UI is similar to the other small sun lights, you probably have to cycle through strobe each time in order to get to off. Not a huge issue when only having 3 modes though.
The only drawbacks I see is size. For a 16340 with an electronics side switch is not that short. The "hand rope fixed hole" thingy does not help in length, it looks to be 2-3mm longer in the front/bezel than I needs to be too.
But its less than 10$ with BLF code.. hmm... tempting, tempting... :)
Do it!
Code is BLF ... it will come down to 9.45
Ill pass for now.. Ill probably regret it if price goes up though.. :p
Instead of ordering the light, I started modding my Fenix E15 (which is not mod friendly). Ill have to wait for a part, so Ill take my time..
If anyone pulls the trigger on this light, tell us how it is! :)
In comparison DX sells it for 16,4$. (it was added several months ago, so its not a brand new model)
DX Youtube video here (seems like I was correct about the UI)
The charging option with that rubber thing really kills it for me. I´m sure it won´t last long/look good after getting it in and out of pockets.
On my ZY-T11 the charging rubber thingy have not been an issue, or anything I notice on my ZY-T11.
My main concern with this light is size.. If the specs is right, it seems quite large for an 16340 light.. Its way too large for a keychain light IMO.
As a pocket light, its not that much smaller than my ZY-T11. The T11 should be more comfortable to hold too, because its longer.
An 18650 tube light (say Convoy S-series) is skinnier and more pocked friendly, and a DQG 18650 is smaller in every way. A light with an 18650 battery have around 6X the battery capacity..
It looks like a nice budget 16340 wide an electronic side switch, but Im not sure sure it does anything that my other lights doesn't do better.
What you say + it cannot replace my beloved L2Ms.
Still looking forward to somebody buying and reviewing this light.
