–2 LED colors (deep red and amber seperatly useable).
-Lumen output: enough to see the trail during nightruns
(I don’t need a lot of light, usually I run in the dark, but in pitchblack forests I need a little bit. A very cheap bike rear light did the job very well in the past).
Option1:
Just buy sorfin 25LR. The sst20 deep red LED should be good for runs.
Pro: easiest option. Just pay 20.99$ +shipping/taxes= 32€
Con: no amber light, only 1button, not elevated light source
Option2:
Modify sorfin 25LR.Change LH351D with Cree XP-E amber.
Question: What is the difference between amber vs amber pc?
Is there an “easy” solution to change the fwd voltage? Would I need a complete new driver or would it be enough to change some resistor values on the MCPCB?
Should I consider another amber LED (Luxeon C or Rebel maybe?)
Pro: amber and deep red lights,
Con: soldering/reflow needed, troubleshooting might drive me crazy
Option3:
Modify sofirn hs20. Change whites with amber/deep red. Use micropuks to power LEDs seperatly.
Question: Would the headlamp become more energy-efficient if I would use a linear driver (only on-off)? Is a linear driver even an option with 18650 and those LEDs? Any other suggestions?
Thank you in advance,
(I am a beginner in electronics, I consider myself capable to solder/reflow LEDs, but I would need a step-by-step introduction for everything more complicated. However I think my stepdad could help me (electrician), but I want to try it myself, first).
I prefer red/amber to not disturb the animals in the forest.
It also feels “warmer” in winter and you get that “special forces” feeling during your runs, which kind of boosts performance.
I like my D25LR. How about putting an amber filter on the white side? Much easier than soldering, although I think you would have fun learning how to do it. Some fiddling will get you the amber color you like.
Yes you are right, I’ll order the 25LR today. It is cheaper&saver, because if for what ever reason I can’t manage to make that amber LED work I still have a red headlamp.
For those in europe, what’s the fastest delivery site for germany? Aliexpress or sofirnlight.com (USA or china?).
It’s funny Quadruple, but running (on the road) in the dark is actually saver than during daytime. During the night you can see the cars from far away and through the trees in curves, especially if your eyes are dark adapted/ you use no/a deep red flashlight.
For my own visibility I have reflectors.
Yesterday night I met a cow on the road, thought it was a biker and felt uneasy because it did not move.
-cree xp-e2 (only difference to cree xp-e is that the xp-e2 uses
silicone carbide technology = sc3)
I think this LED is also used in the weltool 7-AM flashlight, which has a really beautiful and even beam.
-Luxeon C /Luxeon Z /Luxeon Rebel
have strange sizes (2x2mm / 1.3x1.7mm / 4.61x3.17mm) and are unsuitable to replace a 3535(35mmx35mm) LED.
-amber vs amber pc
Amber has 590nm and is used for turtle and wildlife friendly applications since it is invisible for most animals.
Amber pc (=phosphor-converted) uses yellow phosphor on a blue LED and therefor is more pale (amber-white).
-Osram KY CSLNM1.FY sounds like a great option, I’ve read some good reviews about that LED. Also it is a 3030 size I’ll definitely give it a try.
LH351D samsung (35x35mm) will be replaced by an amber LED
Just don’t forget to mod flashlights white led channel output otherwise you will burn your orange led. I ques you need to solder similar value resistors like red channel have.
you will know once you install the LED, whether it produces useful mode spacing with that driver, or at least one useful mode.
Just do it, and share your results.
Good photo!
I did not know you can use 3030 on your 3535 mcpcb… I would stay w 3535 options
good luck w your reflow… it looks like it will be pretty simple, as long as the other components dont move. Some people put Kapton tape over components they want to keep in place…
depends whether you plan to heat the whole mcpcb on a hotplate… or you might just use spot heat from a soldering iron, under the 3535 solder pads…
