The Sofirn HS21 is a T-shaped headlamp with a gesture sensor, one spotlight LED, six floodlight LEDs and three red LEDs. It features an infrared sensor on the right side so that the headlamp may operated by waving a hand.
I respectfully and emphatically take an issue with the suggestion that individual memories for each of the 4 emitter modes is a bad thing. Quite the opposite, and you can always reset them all to Low with a twist of the wrist.
In the review there is the tested runtimes table. For Spot on Med, Flood on Med and S+F on High, Med, and Low there seem to be no ‘reserve’ at the and of the run. Is that correct?
I thought from the runtime graphs and my single test on Turbo S+F that as the battery becomes empty the light always steps down to lower levels and keeps running at Mid then Low for some 10 to 30 min giving a margin of safety regardless of the mode used?
Medium is sustained for hours and then it drops to a lower mode when the voltage gets low. After another 40 minutes it will turn off. I think I was able to turn the headlamp back on in a Moonlight mode.
I tested the runtime on Flood High with Vapcell N40 (so far once, but still).
It went constant (at some 1.2 A draw, probably around 500 lm) for 2 hours and 18 minutes, stepped down to Mid (some 150 lm) for another 26 min, then stepped down again to Low (~30 lm) which lasted for 4 h 15 min.
That’s some 1350 lm•h total in this mode and with this battery.
I’m not sure if it makes sense, but I was thinking that longer runtime, especially on reserve when stepped down, may be due to lower sag under moderate load of the Vapcell battery when compared to Sofirn battery runtimes reported by other testers?
