Read a review before buying the IF25A that mentioned the edges around the lanyard spot were “really sharp!” and thought- that’s a weird thing to mention, not like I’m gonna cut myself on a tiny little lanyard hole.
Now I’m like ohhhhhhh so that’s what he meant.
Hasn’t even left the house yet! Owned it less than 48 hours. That is sharp. And it’s got no clip. No magnetic tail cap. And now no lanyard…so how are you supposed to carry this around? In your pocket? I got stuff in there!
I see you are not familiar with the lack of labor laws in China.
The 9-5 work day, the mandatory breaks, the workplace protections, the EEO laws, and the countless other laws that protect you in the workplace here in the USA, don’t exist in China.
But please don’t take my word for it, research it, as I did, and see for yourself.
Are you sure that your not thinking about "jump rings" rather than split rings. The construction of spring steel split rings includes nearly a full doubling-over of the steel wire. I use a lot of split rings in my paracord hobby in sizes ranging from tiny 6mm rings up to 35mm. There's no way any of the standard steel split rings I use could be pulled apart.
Jump rings on the other hand are constructed with one layer of steel wire, typically wrapped around a mandrel with the opposing ends brought together, but not welded. Jump rings are typically used in the jewelry industry as attachment connectors, such as adding a charm to a bracelet. So for applications where a split ring is typically used, such as for securing a lanyard to a flashlight, then the jump ring certainly could fail where the ends pull apart.
So to @Jeffgoldblum, using a split ring of say, 8-12mm would be ideal for attaching your lanyard. I never string a lanyard directly through the machined hole.
The lanyard nub from hell, digs into your palm too on most lights. Overly used design, simple drill through machining job, must be a cost thing. The thing is the same basic design with the top left intact is a huge improvement.
Now that’s an idea. Might do that for all of them. I can make those really easy.
Do ya one better. Make the spring. It’s super easy. Get a piece of steel wire. Cheapest is usually this stuff just called “mechanics wire” that goes on sale for like $1.50 for 30 feet. Pick a gauge you think you’re man enough to handle. Then either some all thread rod, a long bolt or stud, whatever. If you got a cobalt drill and a big enough bolt you can drill a hole at one end, otherwise just use a cutting disk to make a slit. Stick the wire in the hole or cut or w/e and twist it so it’s stuck there. Take the whole all thread rod and lock it in the chuck of a drill with the wire end in the chuck. Put on some welding gloves and eye protection and then just slowly run the drill. As the drill spins the rod the wire just falls into place in the threads. Use your hand to just guide it. When you got a long enough spring put the drill in reverse and voila. Perfectly uniform spring made to whatever dimensions, whatever strength, whatever thickness whatever material you choose.
I am not a fan of lanyards at all. My IF25A is my EDC, the small holster in this link, Amazon.com is what I use. The other one I use for either my Mag, or my SF47T when I need to carry something with some more heft\throw. It provides good retention without being a hindrance or difficult to remove. You might be able to find it as a stand alone product, but at least you have a jumping off point.
Appreciate it. I never get tired of meeting a fan.
I’m not huge fan of lanyards either, at least not the ones they package with the light, but I need something. Can’t have nothing. At least a clip. I’ll give those a look.
Btw I should say, not that this is a review or anything but just to be fair and to not give the impression that I’m trying to slam sofirn or anything I do like a lot of things about this light. Anduril is awesome, should be in every light. Like the light on the button. Like that there’s some bulk to the head and fins that can provide just a bit of cooling and it doesn’t overheat anywhere near as quickly as some other sofirns/wurkoss’ (and yes I know how to adjust the temp). I especially like the tint on the 4000K SST-20s. And I don’t have a million flashlights but I do have another one with 4000K sst-20s, a wurkoss ts21. Same UI, same 4000K sst-20s, same company almost, but for some reason the color rendering and the tint on the ones in the IF25A are just so much better. It’s like night and day. I can’t believe theyre even the same emitters. Idk if I just got unlucky with the bin lottery on the ts21 or just got really lucky with the if25a or if there’s something different about the lens or about have 4 vs 3 or what but it’s just so much better.
I just wish it had like even just a magnetic tailcap though. Think I’m gonna by a 25x4mm n35 magnet and just super glue it on the outside of the tail cap. I tried to fit one under the spring but there’s not enough space for one big enough.
I fixed more than a dozen of these sharp edges on the
wurkkos fc11 and HD15. I tried various methods and the quickest and easiest way is to just use a nail approximately 1.5 to 2 times the diameter of the hole. Just use a little bit of pressure as you rotate the nail tip in the hole. The sharp cut edges of the nail tip will easily chamfer the sharp edges of the hole. Then I use a piece of sacrificial nylon string that I put through the hole and then saw back and forth in various angles to make sure it’s not shredding. If it’s shredding you still have some sharp edges left. The whole process takes under a minute. Yes, you’re going to remove some of the anodizing. That’s when you swear at the manufacturer for not chamfering the hole before they anodized it. A small split ring will likely do the same thing after a while.
