Sofirn SC13 First Impressions
Sofirn provided me this Review Sample free of charge.
User Interface:
My Lumen Meter, which is not exact, gives some idea of the modes.
Hold from off: 1 lumen (not memorised)
from On, hold cycles 3 main modes (will memorize at turn off)
8 lumens
122 lumens
330 lumens
double clic (from off and from on) 800 lumens (not memorized)
from 800 lumens, double clic strobe (not memorized)
Features:
When first turned ON the button LED glows Green for 5 seconds with a full battery
has tailmagnet
weight 62 grams w stock 18350 and clip
switch button is on a raised platform that protrudes from the head
the USB-C charge port cover is also on a raised platform, on the opposite side of the switch.
I can find the button by feel in the dark, it is not illuminated.
stock battery is button top,
there is physical reverse polarity protection
my flat top keeppower 18350 also works, which means the light can serve as a travel charger and backup battery carrier for my 18350 and 16340 lights
During Charging the button LED is Red. Charge rate starts at 0.74A and drops to 0.42A as the battery nears full charge.
The button light turns green and charging shuts off, when the battery reaches 4.2V.
Opple 3 data for the SST-40 6000K:
CCT 5700K
CRI 61
DUV 0.0127
1 lumen mode has very low PFM, (Pulse Frequency Modulation), about 2% fluctuation, that produces a very Low Flicker Index of 0.0040.
8 lumens mode has 96% fluctuation and produces a High Flicker Index of 0.5838.
No visible PWM because the frequency of the pulses is very fast, about 40KHz
Modability: not easy to open without damage.
There is a press fit bezel and it would need to be pried out to remove the lens and access the LED.
I can get my fingernail under the bezel lip, but was unable to lift it using automotive plastic tools for door panel removal. A blade or small screwdriver might work, but will probably leave marks in the anodising.
What I like:
Nice small form factor with a contoured waist that works well for cigar grip.
Easy UI and useful beam w large floody hotspot.
Built in charging works for both 16340 and 18350
What I would change:
The LED is Low CRI
