For the likes of me, I can’t get my Sofirn SD01 to turn on via my power supply nor an out-of-the-case battery.
I wanted to get some tail amp readings and all manner I tried to devise a secondary power input, the light just doesn’t work. I’ve tried with my homebuilt power supply, set at 4 volts and the current reading is about 5.6 Amps, no light. The voltage fluctuates between 3.56 and 3.88 Volts. The supply can deliver 40+ Amps when pushed.
Then tried a 26650 cell with the same readings. Again no light. Also tried with 4 x 18650 (parallel) – no go.
Naturally, I cleaned all contacts and checked that there is an electrical path.
Magnetic ring (HAL effect transistors), I have no third hand to start from OFF and click to the various levels, so I just left on Max. Unscrewing the battery case a turn, clicking the ring a few notches, and re-screwing the case, the light turns ON. So no stand-by mode is required to pre-drive the MCU and HALs.
My set-up:
The light in question:
I’d have to make a video to better see the fluctuation of the Volts, but it may not be needed as someone hopefully will explain what I’m doing wrong.
