That was instant, but I do not have a proper spacer ring for my lumen tube that fits the SP10 Pro, so the measurements are probably closer to what you would see after 30s if no light was escaping. IMO, in general, with homemade equipment, consider 10% a reasonable margin of error.
I didn’t test turbo in either config, that was just the 5 (simple)/7(advanced) default stepped ramp levels. IIRC, for both UI modes then turbo style is set to 2, where 2C when not at ceiling goes to ceiling, and 2C when already at ceiling goes to level 150.
Sorry Jon, i missed this before.
I appreciate the mode flexibility Anduril gives with regards to adjusting for the Vf of a red LED but i think my question relates to the hardware.
My interpretation of what thefreeman is saying is that on an AA battery the output is voltage-based, so at the same mode setting the voltage is roughly the same regardless of the LED.
So at the lowest mode in Anduril, 1/150, the voltage is enough to light a white LH351D (so somewhere around 2.4v) which should overwhelm a red LED. You’ve shown this doesn’t happen so i’m getting something wrong.
I’ve just discovered one of my SP10 Pros has a parasitic drain of 33mA. I measured this after finding a NiMH drained to 0.85V for third time, and this time i know the torch hadn’t been accidently activated as i has assumed the previous 2 times.
The other SP10 Pro i have in action shows a parasitic drain of about 50uA on the 2000uA multimeter setting.
I’m specifiying the multimeter setting because on the 200uA setting the reading is off the scale which implies it’s more than 200uA so i don’t actually know what it is, but it is orders of multitude less than the one that is killing my batteries.
I don’t know what use this information serves other than to let people know there is a rogue SP10 Pro in existence?
(Hmm, unless it’s to do with the replacement LED i installed, not that i can think how as off is off and both SP10 Pros have non-standard LEDs, in which case it would down to a rogue modifier…)
I have reflashed Anduril with latest version, it works much much better.
I haven’t checked parasitic drain since i leave all tailcaps unacrewed when flashlight is not used.
On the other hand, i was about to ask Barry if i can order just drivers for 3 of my regular SP10v2 and i saw Pro’s are on sale.
14$ folks! Get’em
It is in advanced mode, I’m talking about after the reflash, manual memory no longer works on my SP10pro, but works on all other lights with the new update
did you confirm by doing battery check?
if so, sorry the feature is missing… maybe someone as helpful as @wolfgirl42 or @SammysHP can build you with a new Hex file
Maybe it is just in hybrid memory aka manual memory timer mode? That is enabled by default in the SP10 Pro AFAIK. Check the manual to find out more about it and how to configure it.
