Don’t ask too much
The MCPCB doesn’t fit the SP10A/B without sanding it. I am not sure about the inner diameter of the SP10 Pro, but if it fits without modding the MCPCB, you bet I will try
Don’t ask too much
I tried removing the stars on my FWAA and SP10 Pro to see if I could swap them as-is. Results:
Overall conclusion: The mod looks quite doable, but I’m not sure I want to risk converting my SP10 Pro into a triple until my spare SP10 Pro arrives. Just in case the mod fails by damaging the driver.
Also, I’m not sure whether the SP10 Pro would make a good triple. Since output is limited to just 3 amps, it will have quite a bit worse maximum performance than an FWAA.
The brightness on an IKEA rechargeable is comparable to my tool aa using 14500. Thanks gchart for developing this amazing driver!
Hoping Sofirn gets more in stock soon. I definitely need to order another.
For those who ordered from “SOFIRNLIGHT.COM”: did the status of your order changed to “shipped” (or something similar)?
Mine still shows “awaiting shipment”. I contacted Barry and Sofirn via PM and didn’t get any replies…
I know this week they are on holiday, but mine was ordered on the 14th and didn’t move since then…I’m starting to get upset
Thanks for the report on this Firelight2
I will decide what to do with mine when it arrives. Maybe the triple is an option, maybe not! Let’s see! Thanks
Fwiw, it’s not just sofirn. I have several packages en route from China (mostly AE) and all of them are dead in the water. Most have export clearance success, and then nothing, ranging from 3 to 11 days without any updates. The 1 thing they have in common is that they never left China.
Thanks for the reply Verodin!
I guess yours have avanced more than mine, since I got no tracking number nor clearance , or whatsoever.
I guess this may have to do with the pandemic and the shipping issues during the last months and current restrictions. I mean, I hope it is not a “we forgot to ship your package” issue.
I will wait some more days and see if it moves or not. Thanks :+1:
My order from 4-16 is still awaiting shipping
Got a response from Lan Lee “SP10Pro driver had a problem in the previous test, we sent the SP10 driver back to the factory for re-testing, so the shipment was delayed, sorry.”
Maybe it’s just the new firmware.
Probably June. I too am waiting.
What’s the best way to modify the firmware to access strobe while on? I have no idea how to modify the code and create a hex file
First you should think about which button combination should enable strobe.
For those interested in programming adapters…
I just got a batch of programming kits made up, and most of them are spoken for and have been shipped out. This first batch required modification of the USB to Serial adapter (addition of a Schottky diode between the Tx and Rx lines) so they’re only sold as a full kit. I have a couple of these still available to ship out if anyone is interested.
Also, parts just arrived from a redesign. instead of requiring the USB to Serial adapter to be modified, this version runs both the Tx and Rx lines to the pogo pin adapter and merges them there. This allows you to use this pogo pin adapter with pretty much any off-the shelf USB to Serial TTL adapter without any modifications (* note: if serial adapter has an Rx LED, you will likely need to physically disable that). If anyone would like these, I can send them out as just the pogo pin adapter or as a full kit with a USB to Serial adapter and Dupont cables. If you already have a serial adapter sitting around, this is a cheap/easy way to do the flashing.
Looks very well made Gchart
Nicely done gchart!
What size are the pogo pins? I’ve been looking at buying some, but turns out there’s a gazilion sizes…
Nicely done gchart!
P50-B1 (~0.68 diameter)
PS - the page on Oshpark has the BOM
Big thank you! It’s useful to see your photo and know the actual type. Puts it better into perspective.
I know this week they are on holiday, but mine was ordered on the 14th and didn’t move since then…I’m starting to get upset :cry:
Just wanted to let people know that Sofirn and Barry have replied to me meanwhile, concerning my order. :+1:
They are expecting drivers and updating firmware, so that is what caused delay.
Sofirn mentioned the end of the month to eventually have them.
I will wait for them to become available, as will not cancel my order. I just wanted to know what would be the reason, and now I know :+1:
Gchart you mentioned that shipping to Europe is expensive, should I make some programing adapters for Europeans ? (or others actually, an international 20g enveloppe is 1.65€)
That’d be great, I’d buy one.
It’s relatively easy to hack something like this together (e.g. hot gluing pogo and modding a FTDI board), but it’s an entire different thing if it’s properly done and nice and tidy like gchart’s adapter. Certainly more durable. For small things like this, shipping costs (+ customs!!!) are often a showstopper.
