Hello everyone,
As some of you may have noticed already, Sofirn has just launched their new SP35 flashlight. They have kept the successful "cigar-design" of SP32A V2, boosted it up to 21700 size, included the powerful and reliable Luminus SST40 LED and - most pleasing - added constant current regulation with a buck driver for steady output. Moreover, they added USB-C charging and a new bidirectional clip.
For flashoholics who prefer to have full manual control of stepping down, Sofirn is now offering their first batch without ATR, i.e. without thermal regulation.
What's important to know?
- Turbo and High mode will not step down, i.e. the flashlight will run on full power as long as the battery can deliver enough power.
- Without any interaction on turbo mode, the flashlight will get significantly hot with temperatures of 80°C or above!
- Under any circumstances, never let this flashlight run unattended!
- Never let children play with this flashlight!
- Use turbo and high mode with common sense and manually step down once the light gets too hot in your hands.
Specifications
❖ Emitter: 1x Luminus SST-40 with a lifespan of 50,000 hours
❖ Reflector: Smooth (SMO) reflector
❖ Operating voltage: 3.0V –4.2V
❖ Driver: Constant current buck driver
❖ Battery options: 1x21700 rechargeable lithium-ion battery
❖ Dimension: 126mm (length) × 28mm (head diameter)
❖ Weight: 73grams (without battery)
❖ Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized to military grade specification type III, anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
❖ Toughened mineral glass lenswith purple AR coating
❖ Water resistance i.a.w. IPX-8 (up to 2 meter under water, not for diving)
❖ Mode Memory: memorizes the last brightness level used in the general modes (except Strobe)
❖ Reverse polarity protection from improper battery installation
❖ Low voltage warning
❖ Low voltage protection
User Manual
Please click ► HERE ◄ to download the user manual in English.
Please click ► HERE ◄ to download the user manual in German.
Important notice: Please be informed that this updated manual refers to the SP35 without ATR. This version does not have any thermal stepdown!
Reviews
Youtube:
BLF:
The technical discussion thread
BLF Promotion Prices
[Sofirnlight Webshop]: as of $ 29.99 ➥ 15% off
Please order here: https://www.sofirnlight.com/sofirn-sp35-max-2000-lumen-no-stepdown-version-with-buck-driver-works-with-your-typec-charger-p0165.html
Please use code: WND9F7HE
Available w/o battery or with a 4.000mAh or new 5.000mAh battery
[AliExpress]: as of $ 29.99 ➥ 15% off
Please order here: https://www.aliexpress.com/item/1005001640015568.html
Please use code: KDFOAJWQOAV8
Available w/o battery or with battery
