It’s pretty stretchy, feels like the same as what’s on my other headlamp straps that don’t go over the head. I think the “around” part would hold it sufficiently as long as you’re not jogging with it.
That’s good to know. I hate jogging so that’s not an issue. I just don’t like something going over my head like that if it’s not necessary. It also makes it take up a lot more space when not in use.
I have plenty of time to think about these things since apparently I won’t get it for 25 days or so. I haven’t ordered from China in a long time so I’d almost forgotten how long shipping times can be.
I too would like to see version 2 come with a lighted switch that is on when the main LED is off. Or, have a 'breathing' feature like the Sofirn SC31. As I'm looking at the pictures, the head seems to be the main physical difference between these two rechargeable models.
Heck, after reviewing your (G's) Review, Sofirn should just copy, but with higher output, the driver in the SC31. Output curve looks more in line with the performance commentators here are asking for.
I've gifted or sold all my SC31s but I'd keep what I'm calling a headlamp version of the SC31. It might be updated it with a high CRI SST20 as the temperature regulation would protect it.
Sofirn, perhaps you could bring this all together in V2. V2 might be cheaper to boot!
Current version is L shape, capable of use on head or edc. Next version, I say probably had been better and nicer if it is design like T shape like Acebeam, D10/D25/D25s. T shape is supposed to be a dedicated headlamp only.
Temperature control and heat sinking fins(like D25s)
single head/doublehead/triple head?(just consideration…)
I’m curious what in particular you’re not fond of about the UI? (sincere question, not being a jerk)
Main differences I see between the SP40 and the D25S: the D25S has one additional brightness level, turbo is in the normal rotation, and it has hidden strobe/beacon modes.
The SP32A OTOH, it has the 2 groups: defined modes and ramping. Options like that are great for sure.
Gchart, first of all, congratulations on your family's new addition!
I was thinking about holding off on buying this light but then there was that blessed Vipon discount code. Anyway, somehow, I got the code and wham!, I've got a new addition, too .
When I got it, my question was how fast (rate & time) does it charge the battery in light(?). With the Sofirn stock batt., this is what I found:
I first discharged the battery with an Opus I keep at work so started this charge cycle in the evening. 0.9A isn't too slow but I'm a bit miffed at this taking 5 hours. I guess I'm used to charging with the MiBoxer at the house. If anyone here is familiar with these 'cable testers' you might shed some light about the charge time. Like the OP review findings, the end voltage was around 4.17V.
I've read some fairly negative comments where Sofirn could have added UI features like the SP32A and/or SC31 and I'd like those too. SOFIRN, SEND ME THE VERSION 2 FOR A REVIEW!
But I'm happy with the beam pattern, tint and definitely the 18350 tube. The beam angle is so wide, it's like a mule with a hop spot!
The Sofirn 3000 mAh is curretly in the MiBoxer to compare results between charge options. More to share...
