Sofirn SP70 Alone $50, PM for AMZ US CODE(LIMITED)
I extend the battery tubes on Convoy L6 and Jaxman X6 lights with these…http://www.ebay.com/itm/10pcs-26x32x2mm-Copper-Flat-Washer-Spacer-Gasket-Seal-Fitting-Tighten-Fastener-/321668083019?hash=item4ae4e96d4b:g:ENgAAOSw8a1ZuvN4 when I want to run my 21700/20700 in them.
I ream out a couple26650/18650 plastic converter tubes to fit snug and slightly solder blob or of lately stamp .500-.750mm copper slugs out of copper sheet using a Precision brand shim punch to make the anode contacts and solder them on for my dedicated 2x26650 lights……yeah yeah I know copper oxidizes, I do not care, I have cleaned/polished and lightly coated (all copper components) with No-OX-ID special “A” and had no issues, ever, but that is what I do…ymmv…
Can’t wait for this light. NW tint is good news. Best place to buy 21700 to 26650 sleeves?
Can someone recommend where I can get some good 26650 batteries so I can have them ready?
This depends. Can you add solder blobs or do you need batteries that already has a raised positive end?
I need some with the raised end
Those are bit harder to find locally.
The Aspire 4300 from IMR makes contact in series. It’s a good cell. It pulls 19 amps on my L6.
Then there is the Basen 4500 from Liion Wholesale. I haven’t tried it, but I believe it’s a good cell.
There is the Evva Tech 4500 from MTN.
Maybe someone knows of another?
Shockli BT
And the Aspire should be good for this model correct?
They work fine in my L6.
Merry Christmas!!!
the machines we use, how much do you know about them?
The top 3 pictures look like some type freezer unit at –35C
Bottom 2 pictures are power supplies, integrated sphere, & measuring devices.
That’s my story & I’m sticking to it……. :smiley:
Thank you & hope your Christmas was MERRY also!! :slight_smile:
I don’t know much about it either. I sent a link to Maukka. Maybe he can tell us more about the HP8000Z.
Here is a translated page for the HP8000Z:
Product Name: HP8000Z LED Rapid Spectral Analysis System
A, application function:
● Based on Windows operating system, the human-machine interface is good; standard SMA905 fiber interface, CCD high-speed spectrum; high precision, fast test, easy to use; can be connected to the printer to print test reports, Excel saves data, facilitates analysis; a host configuration related device, Fully meet the light source color and light performance test and analysis of the light source. It is suitable for R&D and testing of laboratories and quality inspection departments. It can also be used for rapid testing of production lines.
B, performance parameters:
● Measure the spectral power distribution of the LED, chromaticity coordinates, correlated color temperature, color rendering index, color temperature difference, fidelity index, color gamut index, peak wavelength, spectral half-width, dominant wavelength, color purity, luminous flux, irradiance, light Effect, forward voltage, reverse leakage current, and other optical color performance parameters;
● The instrument has high intelligence, stable test and high repeatability, which fully meets the CIE requirements for light and color measurement;
1.5 meter integrating sphere light color electric comprehensive test system
C, technical characteristics:
Test speed: 5ms-2s
Wavelength range: 380nm-780nm
Main wavelength range: 380nm-780nm Accuracy: ±1.5nm
Correlated color temperature: 1000k-100000k Accuracy: ±3%
Luminous flux measurement range: 10mlm~50000.0lm Accuracy: Level 1
Forward current: 0.01mA~2000.0mA Accuracy: ±0.5%
Forward voltage: 0.01V~20.0V Accuracy: ±0.5%
Reverse current: 0.01μA~200.0μA Accuracy: ±0.5%
Reverse voltage: 0.01V~30.0V Accuracy: ±0.5%
The first one is a climate chamber to test temperature and humidity over time with different profiles
HP8000Z
is the instrument to the int. sphere, also hocked to the PC
“Climate chamber”…… :+1: … Thanks joechina! :beer:
Will this light be available as a host?
It has not been determined if it will ever be sold as a host. You will just have to wait and see with the rest of us. :smiley:
I think it has to wait after Chinese New Year Vacation…
We are thinking about the SP70 Pro: XHP35 HI in the middle for more throw, several XHP35 or XHP50.2 surround the XHP35 HI for more power, maybe 15000LM
How is that? The challenge will the very high current.
By the way, we found high discharge 26650 cells: 4800mAh, max 24A current. Now Under test in SP70.
I can wait but what about single XHP35 HI version for real thrower drive it to 2-2.5A that easier before go to multi LED
I’m guessing you mean they are 24A continous?
What cells are they?
