Sofirn ST2 Review + teardown
This review is of the upcoming Sofirn ST2, kindly provided by @Sofirn. Aside from the light itself, I receive no compensation for the review.
This is a white/red/UV 3-channel swivel head light powered by 2x18650 batteries. Click on the sections below to read more!
Basic observations
The light comes in a nice box as usual. Aside from the light, also included are a charging cable, lanyard, and a very thorough, large-print user manual, which I found to be clear and helpful for navigating the features of this light.
The light is well-built, with solid anodizing and no sharp edges. The swivel head action is smooth and stable at all angles within a 90-degree range.
Off to the side there is an e-switch at the center of a mode selection dial. On the front there is a type-C charging port protected by a silicone cover, and on the back there is a removable clip held by screws. The combination of the clip and swivel head allows the light to be clipped to a front pocket and point to the front of the user.
At the bottom there are two strong magnets that enable attaching the light to ferromagnetic surfaces.
Emitters, beam, and performance
This light has 3 emitters in smooth reflectors behind an AR-coated glass: SFT42R (6500K) for the main light, plus SST20-DR (660nm) and what appears to be SST08-UV-H (365nm). I think this is a fantastic combination: the SFT42R provides simultaneously good throw and flood, the SST20-DR provides very powerful red, while the SST08 UV emitter throws quite well behind the smooth reflector, and with output very impressive for the small LES.
The hotspot appears slightly lopsided due to imperfect centering, but is not a problem in real use. The red hotspot exhibits some swirl patterns due to the striped construction of the SST20-DR’s die; for this, I would suggest changing the reflector from smooth to OP.
The UV emitter is quite interesting–judging by paper fluorescence, it matches the output of a Convoy S2+ with Seoul CUN66A1G, but in a much smaller and throwier package; furthermore, the forward voltage does not appear excessively high, and the brightness does not drop as much as other UV emitters as the battery depletes.
There is no ZWB2 filter, but this LED emits very little visible waste light. Given the recent discovery of how inefficiently ZWB2 filters transmit 365nm UV, I find this perfectly acceptable.
I don’t have a reliable way to measure lumens, but the claimed 3000lm seems credible, based on emitter tests and ceiling bounce comparisons with my other lights. I measured throw at around 300m, which exceeds the claimed 270m.
I cannot reliably measure the red output, but visually it seems to match an S2+ with 2.5A red buck driver.
User interface
The light has a rotary dial for emitter selection, plus an e-switch for brightness selection. The large-print manual is photographed below:
For both the white and red emitters, the basic UI is similar to Anduril simple mode: click for previously memorized mode (except for moon/turbo), hold for ramp, hold from off/double click for moon/turbo. I find this a good implementation, particularly the decision to not memorize moon and turbo. The ramp is smooth and “visually linear”.
Special blinky modes are available, but well-hidden behind the main menu.
The UV comes in 2 modes spaced around 4x apart (memorized and toggled by holding), which is an excellent design decision. Too many UV lights come in 100% only, which is inconvenient for low-power or sustained usage such as ID checking.
Interestingly, it is possible to have the light on and directly toggle the rotary dial to access the previously memorized mode in the corresponding channel.
Battery and charging
The light runs on two replaceable 3800mAh 18650 batteries, and has a type-C charging port protected by a rubber cover. The charging rate is around 2.2-2.3A, so 1.1A per cell. Some might find this slow, but the slower rate is good for longevity.
The e-switch has an indicator light that tells you the battery level during normal use, and also indicates progress during the charge.
To open the battery compartment requires a torx screwdriver. Once opened, the battery compartment reveals two very thick and stiff springs, which is good for high current. Unfortunately, the springs may be too stiff and slightly dented the minus contact of the batteries. I would still trust the batteries, but if this light were dropped/impacted, the springs might be capable of doing more damage.
Since the current is already distributed across 2 cells, I would recommend using softer/thinner springs. If a battery replacement is needed, make sure the batteries used are flat top and as short as possible.
Teardown and mod!
One thing I love about Sofirn lights is that they are generally modder-friendly, and this one is no exception. The head can be opened by a torx screwdriver, revealing the bezel, an AR glass, an o-ring, the triple reflector, and gaskets & LEDs.
There are 4 wires, with Chinese characters on the MCPCB indicating which color goes where. If I recall correctly, the red pad was a common +, while the yellow, black, and white correspond to the - contact of their closest emitters. In any case, this can be easily checked with a multimeter. The MCPCB is copper and decently thick.
After desoldering the wires and removing the MCPCB, we arrive at the heatsink. It is not a single contiguous shelf: there is a brass (?) block in the middle that is thermally coupled to the remaining shelf by a generous amount of thermal paste. Not optimal, but adequate and convenient.
Lifting the block reveals the driver, which has a large square component thermally coupled to the block by a heatsinking pad. I’m guessing that’s a MOSFET, but someone should correct me if wrong.
Just for fun, I’ve swapped the stock SFT42R for a LHP531 5000K, and the SST20-DR for a partially-sliced 519A 5000K–the 3030 pad accepts a 3535 emitter without issue. I also added frosted tape to smooth out any artifacts. The lights still works fine, though the ramp has become a bit fast on the low end and slow on the high end. I bet the swap of the SST20-DR to the higher-voltage 519A was responsible for this. I think I will keep the light in this configuration until 5000K SFT42R becomes available.
Concluding remarks
[EDIT Aug 13 2026: the swiveling mechanism failed. I will update again when I attempt a repair.]
I think the ST2 is a unique and fantastic light. Although many lights on the market also have red/UV capabilities, they tend to be low-power and treated as a secondary feature. On the other hand, the ST2 offers high-power emitters and the full UI experience on all channels, which makes the channels as powerful/usable as dedicated red and UV lights, rather than an appendage or afterthought.
What I like:
  • Great build quality and swivel feature
  • Great selection of emitters, and high output+throw on UV/red channels
  • Flexible and intuitive UI
  • Replaceable batteries
  • Easy to emitter-swap and convert to arbitrary 3-channel light
What I think can improve:
  • Use softer tail springs to avoid denting cells
  • Use OP reflector for white and red channels to smooth out the beam. Given how large the emitters are relative to the reflector, going from smooth to OP would not visibly lose any throw.
  • Add a battery bank (reverse charging) feature
Thank you for reading!
8 Thanks
Thank you for review.
I wonder how current goes from body to tailcap. Through two screws :thinking: ?
Good point. I have a concern regarding the tensile force from those strong springs on the screws and the likelihood of thread stripping/pull-out.
Thanks for the review.
Few observations:
  • fact, that ZWB2 absorbs certain amount of UV is not relevant for me — it’s just a tradeoff, which I’m happy to make ~every time. Bleaching visible light kills usefulness of UV for anything but glue curing and GITD “charging”, for me.
  • I wonder if the white and red beams aren’t to focused for “chest mounted configuration” — I find it a problem with too throwy headlamps, when the beam “jumps around the scene”
  • the individual memories per channel resemble HS21 (good thing) but the smooth ramping only is a strange decision — I’ve skipped several lights because of it, already
  • I assume that USB-C port is not internally sealed (as it would be proudly communicated otherwise) — I don’t consider flappy port cover alone the sufficient to ensure reliable water ingress protection
  • I wonder about the risk of pulling out relatively small tail-cup screws out of aluminium chassis, by the tensile force coming from those strong springs. I would feel much better about the screws coming from the side (perpendicular to the springs)
Yes, the screws are indeed the electrical path.
That is a solid concern, though fortunately, most people probably won’t have to replace the batteries very often.
I’ve disassembled the battery compartment 3 times for mods, and haven’t seen stripping; however, I had to use a very forceful hand to clamp down on the tailcap, so that the tension of the springs is not felt by the screws during disassembly and assembly.
For the purpose of detecting weak fluorescence, a filter is definitely a must, though plenty of stuff (checking watermarks, mineral/scorpion hunting, etc.) can still be done without a filter. A Convoy 2mm filter cuts 40% of 365nm emission; for the SST08-UV-H, this number will be significantly higher due to an unusually heavy right tail of the emission spectrum.
The best would be a thin/diluted ZWB2 filter, but I suppose that is difficult to implement given the irregular shape of the glass. I’d just slap a Convoy filter in front of it if I really need to. But even then, expect some excitation of the main white emitter due to back-reflected UV.
With the stock emitters, definitely expect some jumping action. Good thing that the LHP531 mod and diffusion film are an option!
That idea didn’t occur to me, but it would be a better engineering decision.
Nowadays, I take four angles to flashlights:
  • does it meet my must have criteria
  • what it offers as-is / for the intended (promised/suggested) purpose
  • what it could offer after modding it
  • what improvement does it give me versus my existing estate
It passes on the modding criteria for me, only. Not good enough to buy it.
Thanks for this review, seems to be a very good light!
Hope they did not use plastic reflector.
The reflector is fully metal. A plastic reflector would be disastrous given the small area and thus high power density.
Another product the world doesn’t need. Sofirn is doing everything it can to keep my money in my pocket.
Thanks for the review!
Where did you put the foil? Behind the front lens and in front of the reflectors or on top of the front lens? Was it sticky or plain?
I put it on top of the front lens (i.e., you can touch it). I did this because the O-ring sits behind the lens, so I didn’t want to compromise waterproofing.
The tape is sticky, which is the only one I have. Sticky diffusion tape is generally better than plain diffusion film because the adhesive eliminates 2 solid-air interfaces and improves transmission efficiency. Rough measurements put the loss of my tape at 2-3%, which is lower than clear glass!
Update: after some light use, the swiveling mechanism became defective and wobbly, no longer able to maintain a fixed angle. Shaking reveals a rattling sound–perhaps a ball bearing has fallen out. Here’s a video of the issue: https://youtu.be/9gJ4i-iamuU
@Sofirn I would like to attempt to repair this myself. Could you suggest how I can get inside the swiveling mechanism to look for the ball bearing and put it back?
On a separate note, I tested the included batteries. They measured over 3600mAh on my VC4, which is more than the <3400mAh of the Vapcell F38, despite the same rating. The high-current performance is essentially identical. I have no idea who made these cells, but they seem to be decent–could you specify the manufacturer?
This happened to me too! I suspected this might occur with other early units. Barry assured me in messages that they had dealt with this in later production runs, so hopefully this doesn’t keep popping up.
Essentially, I found that the ratcheting mechanism had loosened within the light, as it was held down with two small screws that were unscrewed by the vibrations.
Here’s my documentation of the fix: Sofirn ST2 hinge is loose/floppy: teardown and fix
So far the threadlocker has held firm and my light still ratchets satisfyingly!
Happened to me. There’s a fix as mentioned in the other reply…
Pry off the black cap on the side opposite the switch (you’ll need a strong pry tool, it’s also o-ring sealed)
Under the cap There’s two small phillips screws. Tighten one or both until there’s no slop in the swivel. You can over-tighten it so be careful. You can use threadlock, but not necessary as mine hasn’t loosened up over thr last month.
The cap was a bear to get back on. I had to use a big adjustable clamp to press it back on evenly without it getting stuck or cock-eyed.
Thank you so much @Serlite and @Sirstinky for the advice and documentation! I will give this a shot.
A word of caution: I messed up mine doing it. I was stupid enough not to remove batteries and the red wire insulation got cut by a sharp hinge edge when I was dressing it, and there was a spark and now the driver is shot. Also, prying this plug out (and in) is a bitch.
Thank you for the tip–this is really good to know! I’ll remove the batteries before attempting this. Wish me luck removing this plug…
Thank you all again for the help–after half an hour of frustration I found a sequence that works for me. After removing the batteries and covering the work surface with a few layers of cloth:
  • Put a knife blade at the base of the black cap, and hammer it from the back. This should open a slit at the point of contact.
  • Repeat around the circle until the slit is wide enough to insert a flat head screwdriver.
  • Twist flat head screwdriver to pry the cap off–this part should be very easy.
  • After fixing the screws, place the cap back on, cushion with a few layers of tissue paper, and hammer back in place.
I’ve left a drop of 2-part epoxy on each of the screw threads, which should hopefully prevent this from happening again. The light is now pretty scuffed after the half-hour of failed experimentation, but is back to full functionality.
@Serlite @Sirstinky Out of curiosity: did you guys remove batteries when you were doing it? :⁠-⁠)
