I’ve been EDC’ing the SolarForce Z2 at work as a backup light for about seven days, now. It runs on an eneloop NiMH (like almost everything else I have which will accept AA-sized cells)
The Z2 actually does work with 14500 li-ions; albeit it gets fairly warm after five minutes on high; a proper little hand warmer. Holding it tightly will wick away just enough heat so it won’t be uncomfortably hot.
Electronic components in general do not like heat very much in the long run, so I wouldn’t promote to leave it on your desk for purposes of ceiling bounce lighting for longer than ten minutes. It does get rather hot after that.
Total runtime with a freshly charged 900mA 14500 was 37 minutes on high (the cell measured 3.003V on my Gossen Metra DMM when the torch just switched off by itself, and after that, and wouldn’t turn on anymore. I put the eneloop back in, and it lit right up. By the way, this little light cools off amazingly fast.)
UI is not affected by 14500 Li-Ions; the torch will still first light up in the highest mode, the other modes are equally unaffected.
The only concern I have about the Z2 is the switch, which seems to be pressed into the rear of the battery tube. Not only does that smell a bit of “planned obsolescence” to me, but I’m also a bit worried how well it will hold up against water submersion.
my personal mini-review:
PROS:
-brass pill with semi-square cut (more like trapezoidal) threads
-tacticool forward clicky switch
-as always, perfect machining and nice knurling
-green GITD lens O-ring gasket
-nice hand warmer for those cold winter nights
-nice and surprisingly sturdy clip
-a stock Z2 with a 14500 is brighter than a stock Fenix LD10 on eneloops (at three times the cost, I won’t risk the LD10!)
-a lot cheaper than a Fenix LD10, and even more cheaper than a 4sevens Quarc Tactical QTA
-no silly blinky modes
CONS:
-brass pill should have been a copper pill, really
-no apparent way to replace the tacticool forward clicky switch
-a stock Fenix LD10 on eneloops is brighter than a stock Z2 on eneloops
CONCLUSION:
So far, I am pretty much certain that I will buy at least three more of those Z2s as birthday presents for close workmates. Mine will have to pass a couple more tests, though; but I think running a 14500 in it was about the most severe thing I could do to it. Maybe a drop test (or a dozen) from 1.80m/ six feet, and the ubiquitous industrial dishwasher @ 90°C/ 194°F run for two and a half hours.
please note:
1) The lens on both the Fenix and the SF cannot be easily changed if damaged; so I won’t judge the Z2 on that.
2) Since we’re all flashaholics who like to clean and re-lube any threads regardless if they came cleaned and pre-lubed at all, cleanliness and lack of lube on threads and O-rings won’t be even mentioned (oh, to whom it concerns - the Z2 came with clean threads, but zero lube… hence the “Z” in the model name, perhaps? )
3) I will not compare it to a Nitecore EZAA for obvious reasons: the EZAA is discontinued and hence too precious, it is three years old already, and it’s a twisty, not a clicky.
4) Whether or not the ano is type II or III is not really a question for me - most of my HA (type III) torches show more wear than all of my type II M@glites together. I suspect that the layer of a HA finish is too brittle compared to the softness of the parent material, in general. Abrasion resistance is not to be confused with plastic deformation resistance… at least, that’s my conclusion. And, don’t we all like lights with character and personality, proudly telling their stories, an showing their battle marks?
