*EDIT :
I test this light two times and it is overcharge 100% just not sure does all do this or only my sample, for now it is better to avoid, or if some member have same, please post your results. You have 2 pictures below, showing 18650 at 4.7V and 4.43V !*
I buy this light HERE.
It arrive with solar panel detached which is only glued with melted glue on center.
18650 li-ion inside and it is not some light weight, it feels heavy in the hand, on site it write that is 1200 mAh, voltage was about 3.8V when arrive… First night I just test it how it will works in different locations and possitions etc… Next day I put it on direct sun all day so it can be filled up…
At night I collect it and want to measure it is charged or not, and guess what ??
DMM is very precise and I don’t have any kind of problems with it, also don’t know what is happen here that voltage is 4.7V, I see no defects on battery so I go out to try… Run a light 5-6 times for 30 sec go inside and measure a voltage, it shows me 4.15V.
So this is just to warn some users I’m not sure why it hit 4.7V it is some mistake or whatever…
Something other I want to ask since this is my first solar light and I don’t know anything about it. I want to use it indoor, and to put solar panel outside :sunglasses: I have some shed for wood and I don’t have electrical installations in it, so I don’t have light, and when I want to go inside and take woods or whatever at night I must to carry a flashlight…
So I was thinking to add thicker conductors from solar panel to pcb but I’m not sure it will this work due to the length of the conductor and how ‘’strong’’ is solar charging and how this work can cell be charged ?
Conductors that are in solar light right now are wide ( with wrap ) 0.9mm ( don’t know thickness of conductor inside don’t write anything on cable ), and I put 2.1mm with wrap, conductor inside is 0.75mm, put 2 meters for both + and -.
Idea is that solar panel be outside.
And light will be mounted inside.
So what do you think can this work with 2 meters of conductors 0.75mm, more precisely can 18650 be charged with solar panel with this long conductors or not ??
