Well, since I’ve having some issues with my drivers and have gone to direct drive I’m trying to understand the Pros and Cons of each. Other than the modes, what does a driver bring to the table? Is it that it limits the amperage, say from a potential 6A to 3A and thereby prolongs run time? So it will produce less light for longer under regulation?
But with direct drive, it produces much more light initially then falls throughout the batteries useable life. Right? So the output is not consistent as compared to the drivers regulation.
Twice as bright for half as long, or half as bright for twice as long….kind of difficult to figure out what’s best!
For me, the problem seems to be that once you see and use 3000+ lumens, you WANT 3000+ lumens! 2500 is good, and I know it’s better for the light yada yada yada, but it’s an addictive thing isn’t it? Frankly, after that initial start time Wow! Factor, as it runs down a little it’s sorta ho hum….once it hits 2500 it’s kinda boring, lol. Nature of the beast?
I’m fairly certain that the issue with this last driver, run sanely with 4 extra chips at 4.40A, was one of my own doing. I didn’t trim the driver/pill to allow a snug fit but instead left it too tight and had to pretty much force it in. Made it a real bear getting it back out this morning, for sure! No visible signs of any problems, all the chips looked just fine, the 200 ohm resistor looked fine as did the Zener. So I’m pretty clueless as to what happened. Nonetheless, hi would only dimly flickr and lo was barely on at all with medium being the only regular setting. Regardless of cells used, whether in or out of the light. Hooked back up in direct drive, it seems to be just fine.
And this direct drive is the 16 chip board with the neg lead soldering to the ring, bypassing the control circuits…is this ok to run like this or do I need to take a different approach to direct drive?
Any suggestions greatly appreciated. Too much work on this one to bail on it now!
