budget 2xAA torch required, solarforce T2 or L2R which would you choose…
if neither any good budget alternatives?
AFAIK, the L2r hasn’t been available retail for a couple of years. I have one and like it, but I’d guess they go for a pretty penny, but maybe not. There is a current thread here about a Klarus 2xaa for about $23, if I’m not mistaken…I’d take that light any day.
EDIT: here’s the link to the Klarus thread Deal alerts for Banggood.com - BTU Shocker, SolarStorm, Olight, XinTD...
i will check out the klarus thanks.
the L2R is avail at moment on solarforce website, $15.99 for body; does this change your mind regarding klarus?
I would still take the Klarus. The L2r on the website is just an L2 with an extender. The original L2r was a skinny beast designed for only 2xaa. The problem with it is that most P60’s aren’t going to work well on 2xaa. In any case, I’d take the Klarus…ymmv.
EDIT: I should add that I also have a Klarus 2xaa
See my thread here on a 2x-AA sized P60 I built up for a friend, using a 501c host. I've got the parts list including the driver I used to assemble the drop-in. It's worked out really well, is a decent brightness, and low modes make for great runtime...
https://budgetlightforum.com/t/-/21019
I’d opt for the Klarus too. Low voltage P60 drop-ins aren’t very efficient. Output and runtimes won’t come close to the Klarus. And the Klarus is less expensive.
I bought my Mum a Klarus and it’s very good. (I have another li-ion Klarus also).
If you want a 2aa p60 then just convert a Mini Maglite.
As a fan of Solarforce I second all the comments above, go for the Klarus.
Or take a look at Shiningbeam.com and their 2*AA models, like ‘Caveman’ or ‘Spark’, I don’t know if they’ll fit your budget though.
I have an L2R with a Malkoff M31 using 2-AA cells. Very good performer.
I need to amend my earlier statement.
Low voltage P60 drop-ins (that don’t cost $69+) aren’t very efficient.
Awww. Come on now and treat yourself to something special.
I love my T2…. check out my review, it’s stickied here. Its been a great light to me so far
Hello everyone, I’m Tango. I’m preparing to start rebuilding a SureFire C2 as a form of physical therapy and happened across the Solarforce’s website. My query for those who might be better versed with Solarforce bezels is this, will the Solarforce T2 head with LED properly mount and thread on the SureFire C2 host body? Also, I see that they claim their S8 tail switch will work on the 6P, 9P & C2, is this correct? Thanks in advance for any assistance that the forum can offer.
I would really recommend this light, it is fantastic. I did steal a driver from one and put it in a p60 as well… for my old L2r.
Jaxman M2
Don’t have either, let alone both, so can’t quite say.
But even if by chance thread pitch is identical, I’d be careful because some are triangular-cut, square-cut, even trapezoidal-cut. They might “fit but be snug”, in which case be really careful snugging them up.
Thanks for the advise, I was not aware of this. I’m already found a few things that I’ll be using for this rebuild already but I’m in no hurry, just planning and taking my time on it.
Yeah, even with the same mfr, standards change. Eg, ignoring anodisation, some battery tubes are reversible (vs flipping the clip) and others aren’t. Some have different threads in front vs in back. Etc.
I’ve only got L2Ms, and frankly haven’t even tried flipping the tube.
Mixing Solarforce vs Surefire… dunno, but wouldn’t place any bets.
Yes, pretty much all the SureFire line are great lights though they are not all that cheap but you get what you pay for. LOL I’ve been a diehard SureFire carrier ever since the early 90’s and it wasn’t till recently that I started to look into rebuilding a C2. I could easily just through a drop-in in the light and be done but I’m looking to tweak the tail switch, upgrade the lens, give it a space-age look as well as boost its output and maximize its battery life and add a strike bezel.
I know that a few Solarforce items will work on the 6P, 9P, Z2 & C2 host bodies.
any Solarforce host with a c123 extender does 2aa, just need to put some o-rings on the batteries to stop them rattling around inside, I’ve got an l2p with the extender and a low voltage neutral xp-g2 with 2aa nimh that works well for occasional use by the back door.
