SOLD - Astrolux EC03 EDC Flashlight, 6700lm, 500m, 3x Cree XHP50.2, Adoril UI, 21700/18650 Batteries - $29
MSRP: $80
Sales is as is!
Battery not included!
The Astrolux EC03 is a compact, high-output EDC flashlight that runs on Andúril firmware, features built-in USB-C charging, and uses a single 21700 or 18650 Li-ion battery.
Key Specifications
• LED Options: Triple Luminus SST40 (often in 5000K or 6500K) or triple Cree XHP50.2 (3V) emitters on a copper DTP MCPCB.
• Max Output: Up to ~5,700 lumens with SST40 or ~6,700 lumens with XHP50.2.
• Beam Throw: Up to 485 meters (SST40 version).
• Battery: 1x 21700 (recommended) or 1x 18650 Li-ion battery (not included). Opinions on flat-top 18650 compatibility differ on r/flashlight, though models like the Samsung 30T, 40T, and 50E are noted to work, with the 30T suggested for maximum output.
• Charging & Driver: Integrated USB-C charging port; FET+1 driver with electronic side switch.
• Build & Size: Aerospace-grade aluminum with HA III anodizing, IPX8 waterproof rating, 126 mm length × 48.5 mm head diameter, and 175 g weight without battery.
• Included Accessories: 18650 adapter tube, lanyard, and two spare O-rings
