SOLD - Astrolux FT03 Flashlight Set, Copper & Brass, 2400, 900 meter throw - $129
MSRP: $110 (Copper & Brass)
Sales is as is!
Included:
  • Copper FT03 with 26650 battery and original box
  • Brass FT03 with 26650 battery and original box
  • 2x 18650 battery adapter
  • 2x lanyards
  • 2x manuals
The Astrolux FT03 with a Luminus SST40 LED is a high-performance long-range throwing flashlight featuring a max output of around 2,400 lumens and a beam throw up to 875–900 meters.
Key Specifications
  • LED Emitter: Luminus SST40-W, Cool White tint, 6500K
  • Max Output: 2,400 lumens
  • Peak Beam Intensity: ~190,000 cd
  • Maximum Throw: ~875 to 900 meters
  • Battery Support: Single 26650 or 18650 Li-ion battery (using included adapter tube)
  • Charging: Built-in USB Type-C fast charging port
  • Firmware: NarsilM V1.3 ramping/mode user interface
  • Dimensions: Length: 170 mm, Head Diameter: 69.5 mm, Body/Tube Diameter: 34.5 mm
  • Weight: ~301–304 grams (without battery)
Design Features
  • Reflector: Deep, smooth aluminum reflector designed for maximum distance and a tight hotspot.
  • Switch: Electronic side switch featuring an LED indicator light to easily locate the torch in the dark.
  • Body: CNC-milled anti-slip knurling design on a durable aluminum body (note: while mini variants or special editions like copper exist, the standard full-size FT03 uses hard-anodized aluminum; specific solid brass variants are more commonly associated with specialized runs or other Astrolux models like the FT02/FT03 mini variants, so verify your exact host metal if purchasing).
PM sent
